IBM/Simplex Master Clock 25 winding question
Discussion in 'Electric Horology' started by dieselsteveo, Oct 17, 2018.
  1. dieselsteveo
    dieselsteveo Registered User
    Jun 28, 2017
    12
    Indiana, USA
    Hey all,
    I have a IBM/Simplex Model 25 master clock that's of the later design where an electric motor was used to wind the mechanism (see photo). The motor was wired directly by the previous owner, and as such is always running when plugged in.
    My question is this: was the motor intended to be running 24/7? or was the motor supposed to be connected to the switches on the mechanism that would result in it running periodically? I cannot find a wiring diagram on the IBM clock corner that explains the motor wiring.
    Thank you in advance!
  2. JTD
    JTD Registered User
    Sep 27, 2005
    6,708
    346
    You might get more exposure to your question if you posted in the Electric Horology section.
    Perhaps a moderator will move it for you.
    JTD
  3. shutterbug
    40,767
    720
    I don't think it's uncommon for the motor to be under continuous power. It would be held at bay by the clock work, and released to turn as indicated by the levers. I will move this to electric horology for you though.
  4. Scot Traffis
    Scot Traffis Registered User
    Apr 8, 2011
    82
    electical tech
    parma oh
    The motor runs continuously. I have two master clocks with this setup. The motor winds a spring and cannot over wind it. I will look to see if I have a wiring diagram for this style clock
  5. dieselsteveo
    Jun 28, 2017
    12
    Indiana, USA
    Thanks everybody. I was primarily concerned about the life of the motor, not over winding.
  6. paradise
    paradise Registered User
    Jun 24, 2007
    91
    Scott Traffis: could you contact me at paradiseclocks@cfl.rr.com. If you don't mind I would like to ask you a few questions on your synchro wind clocks.
    Thank you Marco Roberts.
  7. paradise
    Jun 24, 2007
    91
  8. JTD
    JTD Registered User
    Sep 27, 2005
    6,708
    346
    You could click on his name and start a 'conversation' (the new name for private message on this board).
    JTD
