IBM master clock 35
Discussion in 'Electric Horology' started by Kevin W., Feb 19, 2019.
  1. Kevin W.
    Kevin W. Registered User
    22,623
    392
    Hi again. I was wondering if someone has some information on the pulley hanger assembly on the ibm master model 35, i removed the hanger and pulley on the left side, it had a small coil spring and a ball bearing. I tried to put it back together and eventually the ball bearing is now on the floor, pretty sure it can be found.Are both pulley hangers made the same way, and how does one assemble this, i could not.
