captainclock
Hello Everyone, a couple of years ago I had gotten from my Great-Grandparents House when we were cleaning it out so we could sell it an 1858 Seth Thomas Column and Cornice Clock (which most of you guys are probably familiar with my never ending fights I had with getting that clock to run and stay running correctly.)
Anyways I did finally get it working correctly (or as correctly as a 160+ y/o clock can work) and the odd thing is that everyone on here was insisting that the size of the pendulum bob didn't matter when it came to how the clock ran, but apparently that wasn't the case with my Seth Thomas clock, because I had previously had the clock "running" (it was running but not correctly) with a larger diameter pendulum bob because someone else on here suggested that my clock should of had a larger diameter bob because that's the way their's was.
But after I finally made the necessary repairs to the movement to get it to run like it was supposed to (including getting the correct verge assembly) the clock was having trouble losing time with the larger bob (no matter how high the bob was raised) and so I tried a smaller diameter bob that I had ordered along with the larger diameter bob ( from when I was trying to figure out which size I needed to use with this clock) and sure enough the clock has been spot on accurate with the smaller bob adjusted to the center of its adjustment plane, so it seems that in this case size does matter in terms of the bob and how the clock runs.
Is there anything to what I've just experienced here or is this just some weird fluke?
