I inherited my mother-in-law's clock
Cindy Deaver
New Member
Dec 23, 2017
Just wondering if anyone knows anything about this clock, it still chimes...but doesn't have the glass facing
bruce linde
ADMIN / MODERATOR
8,853
1,370
oakland, ca.
clockhappy.com
hmm... i think we need a better closeup of the dial (more in focus)... also, is there any way to see in the sides? is there a back panel that comes off and exposes the movement? we need to see behind the curtain (dial)... if there's a way to get photos of the movement that would be a big help in identifying what you have.
also, the glass can be replaced... a photos of the inside of the bezel that shows any clips that might have held the glass in place would help.
Chris
NAWCC Business
Nov 4, 2001
2,475
Ellsworth, Maine
clocksbychristopher.com
Wuersch was a clock builder (note I didn't say "maker" as he did not make his own movements) in Fall River in the 60's through the early 80's. He used Hermle clock movements and built his own style cases. As I understand it, he came to the US and started his business, but later closed for failure to pay taxes. The finish on the case looks like stain with no varnish, which indicates either it was refinished or someone else may have built it and used a leftover Wuersch dial.
Dave T
Dec 8, 2011
3,602
208
NC
Here ya go, You're right Chris. It's very clear in my file, but doesn't translate here quite as good. But it definitely is Wuersch.
ragobo
Apr 14, 2015
222
Barcelona
No idea if the case is original or not, although I'd tend to think it should be. It looks gorgeous with its Christmas decorations :)
A pity about the front glass, but with patience I think you could end finding a replacement. The chimes must be nice to hear too.
Reactions: Cindy Deaver
JTD
Sep 27, 2005
8,833
774
Shouldn't be difficult to get replacement glass, either flat or convex. Flat glass could be cut to size by any local glazier, convex glass is available from the usual clock material suppliers.
However, it is not clear (to me) from your pictures as to whether the bezel is still there or if it has broken off at the hinge. Even if it has, that could also be replaced,
JTD
167,023
1,455,481
87,253
javalink
