I have a Detex Night Watchman's Clock and need help please ..
Discussion in 'Clock Construction' started by Jamie McKay, Mar 2, 2013.
  1. Jamie McKay
    Jamie McKay Registered User
    Feb 20, 2013
    15
    Hi I have a Detex Guardsman clock that I would like to open so I can find out what's inside.. I want to know if there is a diagram that I can find on how to pick the lock. I would like to see if there are gears and cogs for jewelry making and I want the outer shell for a steampunk purse... I do not have a key. thanks! Jamie eclecticgatherings@hotmail.com
  2. Kevin W.
    Kevin W. Registered User
    21,794
    237
    Kind of too bad you are going to make jewellery out of this clock.
  3. Jamie McKay
    Feb 20, 2013
    15
    I would much rather wear it in pieces than to not wear it at all... the "purse" will be put to good use... as of now it is not being used.. jewelry is a good thing..it's only worth something to the owner and not worth anything if I can't play with it.. right? I will pass it on down but with a lot less weight... :)
