I am polish ignorant help?
Discussion in 'Case Construction, Repair & Restoration' started by ChrisCam, Mar 29, 2019.
  1. ChrisCam
    ChrisCam Registered User
    Dec 9, 2017
    1,377
    27
    England
    Hi, the only polish in my tool kit is natural beeswax. Can anyone suggest the type of polish they recommend for any particular wooden clock type.
    Regards
    Chris
  2. JTD
    JTD Registered User
    Sep 27, 2005
    7,266
    447
    It depends a lot on what sort of finish you are dealing with. If the wooden case is lacquered, ebonised, stained, natural and so on. Is the case clean? I always use a clock-case cleaner before any polish. This removes nicotine and any other grime and lets you see what the case is supposed to look like, without destroying the finish.
    Then the best I can say is that normally, good quality wax polish, such as Liberon, which is available in a range of colors, is suitable. Avoid anything which contains silicone.
    Your natural beeswax is also fine, although of course it is (presumably) colorless.
    Hope this helps a little.
    JTD
  3. ChrisCam
    Dec 9, 2017
    1,377
    27
    England
    Thanks using a clock case cleaner is something I did not know.
    Chris
  4. oricko
    oricko Registered User
    Apr 30, 2011
    34
    retired
    grass valley, ca.
    A suggested case cleaner would be ?
  5. D.th.munroe
    D.th.munroe Registered User
    Feb 15, 2018
    423
    151
    Full time clock and watchmaker
    BC Canada
    It really depends on the finish, but I see alot of people using gojo or some type of waterless hand cleaner as a case cleaner with good results. There is special cleaners you can buy from suppliers.
    I use Renaissance wax for alot of things. I haven't used it on a wood clock case yet but I've used it on guitars and other things.
    rascalsally likes this.
  6. Chris Radano
    Chris Radano Registered User
    Feb 18, 2004
    3,648
    205
    Pennsylvania
    I use New Life if I need a cleaner. Used to find it on Ebay but not lately.
    Furniture Masque The Grime Cleaner for the Dirtiest Wood and Furniture
    Yeah, a lot of things will probably work. But New Life makes even me say, "wow". I apply with an appropriate sized paint brush. Wipe off, let set for a week or 2, then wax.
    For wax I use either Renaissance, Behlen's Blue Label, or Clapham's Beeswax polish.
  7. ChrisCam
    Dec 9, 2017
    1,377
    27
    England
    Really useful chris...thanks!
    chris
  8. bangster
    bangster Moderator
    19,633
    389
    Yep. New Life Furniture Masque. Won't affect lacquer or shellac.
    I've used Johnson's carnauba paste wax.
  9. JTD
    JTD Registered User
    Sep 27, 2005
    7,266
    447
    I am sure New Life Furniture Masque is very good, but unfortunately it does not seem to be available in UK, which is where the OP (ChrisCam) is. Gojo can be bought in UK with great difficulty and very expensive.
    The one I can recommend that is available in UK is 'Curator' Clock Case restorer. It is excellent and a little goes a very long way. It will surprise you have much grime and dirt you can remove. (It is also available in USA, as Timesavers import it from UK).
    As for Behlen's and Clapham's, they are also not available in UK. However, Renaissance Polish (colorless) is available in UK, and is indeed very good. The Briwax colored polish range is excellent, as is the Liberon range.
    Hope this helps
    JTD
    ChrisCam likes this.
  10. rascalsally
    rascalsally Registered User
    May 21, 2016
    11
    CT, USA
    I saw this thread and expected a whole different topic, lol.
    As to the wooden clock waxes / cleaners would antique furniture restorer type products work or is there something specific or reason to avoid certain type products. I have a couple old clocks I wanted to clean up and I was going to use what I've used on antiques (wooden) in the past on them. (Please don't ask what it is because I'm currently in process of pulling my hair out trying to remember the name.) One of the clocks has some serious heavy orange peely kind of buildup that I've come across on antiques before. I had used a product a few years ago that worked amazingly well on a few chairs I had aquired. Anyway I guess I'm just wondering if specific types of cleaners/polish should be avoided when using on antique wooden clocks?
    Thanks!
    ~Sally
  11. JTD
    JTD Registered User
    Sep 27, 2005
    7,266
    447
    Well, if you read the posts above yours you will see quite a lot of the information you are requesting.
    I suppose the basic rule is: use nothing harsh. Clean the case as has been described, then use any good quality wax polish, but preferably one that does not contain silicone.
    Antique wooden clocks are not really any different from antique wooden furniture.
    The 'orange-peel' effect you describe sounds as if you may have old shellac which has 'alligatored'. There is plenty of advice about this on this website - use the little magnifying glass icon to search.
    Photos of what you are talking about would also help.
    JTD
  12. ChrisCam
    Dec 9, 2017
    1,377
    27
    England
    Thanks JTD for the UK recommendations. There usually is a UK equivalent just a case of finding it.
    Chris
  13. ChrisCam
    Dec 9, 2017
    1,377
    27
    England
    Thanks Sally, yes you do have to watch how you use words as polish with a capital could mean something not intended.
    Chris
    D.th.munroe likes this.
  14. Old Rivers
    Old Rivers Registered User
    Oct 4, 2016
    99
    North Texas
    For cleaning old, dirty finishes I've had excellent results with "Kotton Klenser"
    www.kottonklenser.com
    Bill
  15. ChrisCam
    Dec 9, 2017
    1,377
    27
    England
    Thanks Bill every little helps
    Chris
  16. PatH
    PatH National Program Chair
    NAWCC Fellow NAWCC Member
    Dec 5, 2014
    1,565
    1,073
    Female
    Texas
    Another tip is to try any cleaner in a small, inconspicuous spot first. Some finishes are very fragile.
