• Upcoming updates
HWN tall case info?
JeffG
Jul 8, 2020
352
152
St. Croix, U.S.V.I.
Good day!
I have taken in this wayward clock and would appreciate any info you guys could provide- particularly age/history, tips/tricks/pitfalls of the movement, etc
The striking weight has dropped down into the case for some reason, so I will be checking for a bad click and bent arbors. The suspension spring is broken, too. Beyond that, I haven't really gotten too deeply into it yet.
Thanks!
HWN Case front.jpeg HWN case front top.jpeg HWN case front bottom.jpeg HWN case inside.jpeg HWN dial.jpeg HWN back stamps.jpeg HWN back plate.jpeg HWN hammers.jpeg HWN movement top.jpeg
edited to add-
new2clocks
Apr 25, 2005
4,761
1,004
Pennsylvania
The 'HWN' trademark was registered in 1919 by Hausuhrenfabrik Winterhalder KG .
The 'Hawina' trademark (and the Hawina brand, so to speak) were registered in 1925 by H. Winterhalder A.G.
Since the Hawina trademark is on your movement, and since Winterhalder went out of business in 1929. your clock was made between 1925 and 1929.
Regards.
Reactions: JeffG and Tatyana
Thomas Sanguigni
Aug 22, 2018
804
224
www.secondhandclockshop.com
Nice looking clock. The dial looks a little bare bones, but I like the carvings. Concerning the weight drop, there may be stretched links in the chain or the stop fell off. Look over each and every link in the chain.
wow
Jun 24, 2008
7,106
1,337
77
Pineville, La. (central La.)
Jeff, I have serviced several HWN movements and found them to be very well made movements. If yours is the one with the huge weight on the chime train, check the pivots in the chime train carefully. I remember having to bush a few. The pivots are usually not bad at all. Just fine polishing. They are a pleasure to work on.
Reactions: LenzkirchFan
JeffG
Jul 8, 2020
352
152
St. Croix, U.S.V.I.
...found them to be very well made movements.
Indeed this is a much higher quality movement than I have had the good fortune to work on previously. I am intimidated by the adjustable pallets on the anchor and the internal (between-the-plates) chime wheels and levers. Thankfully the eccentric bushings seem unmolested.
The weights are roughly 9 lbs for the chime and strike trains, and about 7 for the time train.
-Jeff
wow
Jun 24, 2008
7,106
1,337
77
Do not even think about adjusting those pallets. If the bushings are snug, they will be fine. Ask me how I know. I only did it once.
Royce
Oct 8, 2018
390
124
71
Houston
Jeff, I agree with Will 100% in that you will enjoy working on this well made movement. I have the same movement in one of my GF clocks that I restored and it is well built and extremely reliable and accurate. Enjoy.
Royce
wow
Jun 24, 2008
7,106
1,337
77
Hey, Royce. You going to the regional in Houston?
Oops, just saw your response in. PM. Sorry you won’t be there.
Royce
Oct 8, 2018
390
124
71
Houston
Will,
Sorry I am unable to attend. It would have been a pleasure to meet you. Enjoy.
Royce
180,053
1,570,728
54,363
mickri
911
3,090
