• Upcoming updates
HWN/Hawina BPH?
JeffG
Jul 8, 2020
353
152
St. Croix, U.S.V.I.
Good day!
Could someone please help me understand how to calculate BPH for this time train?
The two wheels on T2 are confusing me.
-Jeff
new2clocks
Apr 25, 2005
4,761
1,004
Pennsylvania
Is there any information on the backplate? Some German manufacturers will stamp the backplate with the BPM.
Also, your title does not distinguish between a HWN marked movement and a Hawina marked movement. Although they were made by the same company, they are different movements.
Can we see a picture of the backplate?
Regards.
JeffG
Jul 8, 2020
353
152
St. Croix, U.S.V.I.
Sure!
JeffG
Jul 8, 2020
353
152
St. Croix, U.S.V.I.
Isn't that upper wheel part of the motion works?
The upper wheel on T2 is clutched, and drives the 30-toothed wheel on the center arbor. The same wheel on the center arbor also drives the intermediate wheel which drives the hour cannon.
-Jeff
18,255
3,654
Only thing different will be the 30 to 72 gear down to the 2nd wheel pinion, all else is the normal gear up to the escapement. Willie X
JeffG
Jul 8, 2020
353
152
St. Croix, U.S.V.I.
I don't understand. There is no 72 gear. The 30 teeth on the center arbor mesh with a 48 toothed wheel on T2's arbor, but a 75 toothed wheel drives the rest of the train. Maybe my poor penmanship has thrown you off?
My confusion stems from that smaller extra wheel driving the center. I know that on an American-style auxiliary driven center you disregard T2 altogether in the BPH formula, but in those cases the same wheel is driving both the center arbor and the T3 pinion.
I know that, due to the pendulum length, BPH should be between 3,800~4,000.
-Jeff
edited to add-
JeffG
Jul 8, 2020
353
152
St. Croix, U.S.V.I.
Holy cow I might be onto something!
If I assume that the 48 toothed wheel on T2 is acting as a pinion in the train between the EW and center arbor, the math works out to 3,984.4. That's about right for this 33-ish" pendulum setup.
I don't know for sure if I'm correct, but I'll be able to sleep tonight.
Ultimately, I suppose the clock will tell me if Im wrong.
-Jeff
49,693
3,032
That upper wheel in not involved in the calculation.
dickstorer
Oct 19, 2010
896
85
89
Hampton, Georgia
I may be wrong but I think the upper wheel on T2 serves the same purpose as it would if on the center wheel arbor. So it is 48 x 68/8 x 40/8 x 2 =261120/64 = 4080 BPH To go farther find BPM square that and divide that number into a constant of 141120. 4080/60 = 68 BPM. 68 squared is 4624 So 141120/4624 = 30.519 inches Theoretical pendulum length
180,081
1,570,922
54,367
shaimerej
911
3,090
