Hunter finds his prey
Discussion in 'Case Construction, Repair & Restoration' started by gleber, Jul 13, 2019.
  1. gleber
    gleber Registered User
    Jun 15, 2015
    1,731
    193
    Underwater Robotics Expert
    Downingtown, Pennsylvania USA
    #1 gleber, Jul 13, 2019
    A while back I bought a French figural clock with a hunter and his dog. Unfortunately, the bird or rabbit he was holding was missing.
    Statue Clock or Figurine Clock? Either way I found another and another.
    I finally got around to making a replacement. I'm still working on the movement, so the dial is empty, but I think the hunter and his dog are much happier now that he is successful once again.
    20190713_122900.jpg 20190713_122900.jpg 20190713_122941.jpg 20190713_123333.jpg 20190713_123402.jpg 20190713_130208.jpg 20190713_130215.jpg 20190713_130309.jpg 20190713_123042.jpg
    Love clocks likes this.
  2. shutterbug
    43,167
    1,182
  3. PatH
    PatH Registered User
    NAWCC Fellow NAWCC Member
    Dec 5, 2014
    1,649
    1,130
    Female
    Texas
    Can you tell us a little about how you made the bird? I know you have great carving skills, so just wondered if it's carved and gilded. Thanks for sharing your work with us!
  4. gleber
    Jun 15, 2015
    1,731
    193
    Thanks for the kind words about my carvings.
    Sure... It was a piece of mahogany scrap. I carved it using straight blades (like Xacto) and small diamond burrs in a hand grinder (like Dremel). To start, I sketched the top and side profiles on a small block and roughed it down to those in each direction. I let one wing droop a little more so it would look more natural. Then, I added details like removing wood under the wings, shaping the breast/legs and the claws. I didn't have a model, I've carved birds and guess I'm just good at visualizing things in 3D. On the body, I used a fairly coarse burr to simulate the finer feathers.
    I finished the feather carving and details on the bill and eyes using a pencil soldering iron with a tip filed into a tiny angled chisel point. If you use a blade, it will cut then heal. The hot iron burns away to create a groove. You can try to cut a V, but it's hard to keep the edges parallel. I haven't worked with gouges, but I am planning to get a set someday. For the feathers, I tilt the iron so the overlapping feather has a sharp drop and burn more on the underlying feathers so they appear to slip underneath.
    I had to cut away the areas where the hunter's fingers go. I did that by trial fitting and working a little at a time until it almost sat in his hand on its own. I did glue it though.
    When the carving was finished, I used Gold Leaf Rub'n Buff. It covers wood pretty well. I had already used that on the whole statue, so it made sense.
    I would like to see what was originally there and be able to inspect the details. For some reason, I think a rabbit would look better. Hmmm...
    Tom
  5. PatH
    Dec 5, 2014
    1,649
    1,130
    Female
    Texas
    Thank you! I think being able to visualize in 3-D (along with a steady hand) is key.
