Hi all,
I have a Cuckoo Clock for restoration, fitted with a Hubert Herr movement, and naturally want to replace with the exact same movement.
However with reference to the Black Forest Imports catalogue it shows type AM60 as the only 30 hour movement remotely similar to the one fitted to this clock.
However the plate size is shown as 62 X 68 mm, where the unit in this clock has a plate size of 75.5 X 79 mm. with a very different plate layout.
Which, I assume would mean that the hole centres in the case would not line up with the new replacement.
I have included a picture of the original movement for reference. Does anyone know if this original has been replaced with the smaller type, or is there a possible replacement for this clock?
I have looked at the possibility of substituting with a 'Regula" movement with similar dimensions, but with the information I have can't be sure if the chain wheels are in the same position.
Has anyone run up against this before, if so what is the answer?
Regards candix
Regards candix
