American Hubble calendar
Discussion in 'General Clock Discussions' started by Clockem, Nov 29, 2018.
  1. Clockem
    Clockem Registered User
    Mar 1, 2011
    #1 Clockem, Nov 29, 2018
    How do you wind the lower calendar movement on a Boardman Hubble clock? The lower movement runs for a year. It has a hole on the lower right side so as to wind it with a long key. When the key tries to wind it, the rollers just rotates to the next days, but the small spring does not wind. Is it possible that there is a small part missing that helps to engage the winding of the spring?
    I will try to send a photo of the lower movement.
  2. bruce linde
    bruce linde Technical Admin
    6,763
    821
    oakland, ca.
    you probably don’t... typically calendar clocks are triggered by a rod that runs from the main movement down to the calendar mechanism.
    do you have one? photos would help... can you see the lower/calendar movement w the door open?
  3. Clockem
    Mar 1, 2011
    #3 Clockem, Nov 29, 2018
    Here are a couple photos.
  4. bruce linde
    6,763
    821
    oakland, ca.
    so you see the rod, yes? were you asking because it’s not working?
