Hti Clock cleaner and Substitute
Discussion in 'Clock Repair' started by DeweyC, Apr 10, 2019.
  1. DeweyC
    DeweyC Registered User
    Feb 5, 2007
    2,056
    721
    Watchmaker
    Baltimore
    I have been getting a lot of emails from people who are sorry to see the demise of my cleaner. Timesavers just wasn't having enough call for it and I hate retail.
    Here is a basic formula that works as a subsitute. Be aware, ammonia is used to turn the oleic acid into a soap. Free ammonia is waste and doesn't do much of anything.
    Dewey
    fbicknel and Troy Livingston like this.
  2. Troy Livingston
    Troy Livingston Registered User
    Aug 28, 2006
    158
    19
    Aerospace Stress Engineer
    Melrose, FL
    Thanks Dewey. I was also sorry to see it go.
    Troy
  3. bangster
    bangster Moderator
    19,633
    389
  4. R. Croswell
    R. Croswell Registered User
    10,001
    756
    I'm surprised to see it go but they still offer Deox-007 Polychem Nonammoniated Deox-007 - 1 Gallon which I find to be perhaps a little better. It seems to brighten brass just as well, mixes easier, rinses cleaner without an alcohol requirement, and doesn't thicken on prolonged standing, and doesn't get cloudy in the cold, and costs a few bucks less for a gallon. Perhaps that's why they dropped their other product?
  5. bangster
    bangster Moderator
    19,633
    389
    I still have most of a gallon of HTk, but when it's gone, I'll give Deox a shot.
  6. sharukh
    sharukh Registered User
    Oct 10, 2011
    353
    14
    Doctor
    Mumbai, India
    Dewey,
    What is the book that this page comes from ?
    Sharukh
  7. DeweyC
    Feb 5, 2007
    2,056
    721
    Watchmaker
    Baltimore
    1959 Waltham catalog. Same pages are in Whitney Military TImepieces.
    Not to be a jerk (even though I can be), but I have seen corrosion problems with Polychem. Maybe the pieces were not rinsed or cleaned properly, but be sure to test first. And this was early on.
    Also, an advantage of Daniels solution is that it is environmentally friendly. It is simply a soap.
  8. R. Croswell
    10,001
    756
    I would be interested if hearing if others have experienced corrosion with Polychem Deox-007. I've used it for a couple years and so far have not seen that problem. I have seen green corrosion with other cleaners including alcohol and mineral spirits but it seems to happen when and where the brass may not have gotten completely clean and some residual crud was left behind. Has anyone tried La's Totally Awesome Cleaner" from the Dollar Tree? It's a great grease getter and doesn't seem to attack brass but does not contain ammonia and will not brighten brass. I suppose one could add ammonia.
  9. Kevin W.
    Kevin W. Registered User
    22,248
    311
    Been using Deox 007 for about 8 years, i make sure my parts get really dried well in the oven after rinsing them with hot water. I have had no corrosion problems.
  10. fbicknel
    fbicknel Registered User
    Apr 14, 2017
    424
    60
    Cumming, GA
    I wonder what the "rinsing solution" is of which they speak. It somehow deserves its own 2-gallon container, according to the literature.
  11. fbicknel
    Apr 14, 2017
    424
    60
    Cumming, GA
    I welcome corrections, as this calculation is off the cuff, but assuming the ammonium hydroxide mentioned in the article is 28% and assuming that clear (no soap) household ammonia is approximately 5% (I see values of 3% to 10%; most seem to settle around 5%), then you could substitute 22 ounces of 5% household ammonia for the 4 ounces of ammonium hydroxide and fill to 1 gallon with distilled water as suggested.
    I figure that 22.4 ounces of 5% ammonia is approximately 4 ounces of 28% ammonia and 18.4 ounces of water.
    I didn't do any molar calculations and it's been a few years since high school chemistry, but based on volumes and concentrations, I believe this to be accurate.
    If your household ammonia is 3%, then go with 37.3 ounces instead of 22. If it's 10%, then use 11.2 ounces of ammonia.
  12. fbicknel
    Apr 14, 2017
    424
    60
    Cumming, GA
    If you would like to make 2L of this instead of 1 gallon, then add 62.5ml of each of the chemicals mentioned and add enough water to make 2L.
    To use my household ammonia substitution above instead of ammonium hydroxide (28%), then use 350ml ammonia if it is 5%, 175ml if it is 10%, and 583ml if it is 3%. Fill to 2L as usual in each case.
