Howard Tower Clock Running Fast
Discussion in 'Tower, Monumental & Street Clocks' started by William Shoucair, May 28, 2019.
  1. William Shoucair
    William Shoucair Registered User
    Apr 23, 2019
    7
    I am maintaining our town's Howard tower clock (model # 1 roundtop strker) and it's running quite fast - picks up about 4 minutes a day - I've turned the timing knob on top of pendulum quite a bit counter-clockwise but there is not much screw thread left. Any other way to slow it down? Remove some weight?
  2. Uhralt
    Uhralt Registered User
    3,815
    374
    It depends on the type of escapement the clock has. If it is a recoil escapement, less weight will slow it down. A deadbeat escapement will likely not slow down considerably but just stop if there is too little power.
  3. William Shoucair
    Apr 23, 2019
    7
    It must be a deadbeat - the anchor sides are equal and I seen no backward recoil. Wouldn't a a Howard tower clock from 1902 be a deadbeat?
  4. bruce linde
    bruce linde Technical Admin
    5,615
    506
    oakland, ca.
    photos? what’s the weight made of? any chance a piece came off?
    when did you notice the change in accuracy?
  5. shutterbug
    40,688
    709
    Or perhaps the pendulum was altered some time in the past?
    I'll move this to the tower clock forum for more input.
  6. Jim DuBois
    Jim DuBois Registered User
    NAWCC Member Sponsor
    Jun 14, 2008
    2,555
    420
    Magnolia, TX
    Yes, E. Howards are deadbeat escapements. Usually, there is also an adjustment or regulation knob on the bottom of the pendulum bob. They are not often used, there maybe a screw through the bob that clamps into the shaft. It must be released before using the rating nut on the pendulum bottom.
    Peter A. Nunes likes this.
  7. bptanguay
    bptanguay Registered User
    Apr 5, 2012
    198
    12
    Watchmaker
    Massachusetts
    Where is the clock located?
