Howard street clock restoration details.
Peter A. Nunes
Mar 3, 2006
1,660
26
Rhode Island
www.cogcounters.org
I'm enjoying this street clock restoration, and rather than continue to add new threads as I go through it, I'll put further comments here.
Today's little project was cleaning, priming, and painting the two sheaves (pulleys) that are used- one hangs in the case, the other is installed directly in the weight. I had to grind off the end of the shaft to get the weight pulley out, and then peen it a bit to get it to stay in again. For those who are interested, the weight, which is lead, weighs 109.5 pounds, including the sheave.
Peter A. Nunes
Mar 3, 2006
1,660
26
Rhode Island
www.cogcounters.org
Any wobble in the pins/pulley bore? Were they drilled to hold oil?
There is a bit of wear, but very little. The bushings are all smooth, the steel pins seemingly unworn. Since these turn at a remarkably slow rate, that's not surprising. There are three holes for oiling in the hub of the sheave in the weight, none in the pulley.
167,209
1,457,101
87,372
Pamula
