Howard Miller Longcase question
RoystonSmythe
Nov 20, 2020
25
67
I went on a call today to look at a Howard Miller model number 610-406 three train Longcase.
The owner had recently moved and sure enough they had left the pendulum on which had managed to jump off the suspension spring and bend the leader. No actual damage done. What I cannot understand is what this piece is for. Screwed onto the back cock and through the suspension spring. Almost impossible to put back on as you need about 6 hands to hold all the bits at the same time as putting the screw in, all through a side hatch and around the strike rods. Very user UNFRIENDLY compared with antique Longcases. Any information on this part would be welcome, thanks - Roy
wow
Jun 24, 2008
7,739
1,765
78
Pineville, La. (central La.)
That is part of the auto-beat feature. It fits on the suspension spring post and the solid piece of the suspension spring hits it as the pendulum swings. It’s needed if the auto-beat is to work right.
19,579
4,633
I thought it was there to protect the suspension spring from minor accidents and keep everything together during shipping. Same function as the little black plastic
'do-dads' that simply slip on the post from the back. Willie X
wow
Jun 24, 2008
7,739
1,765
78
Maybe that’s right. I always thought they had to stay on for the AB to work right.:???:
Dick Feldman
Sep 1, 2000
3,437
713
Colorado, usa
That is one of those touch but cannot see pieces. I think both WOW and Willie X are correct.
Sometimes it is easier to pull the movement and install, rather than drop the pieces a dozen times or so.
Dick
RoystonSmythe
Nov 20, 2020
25
67
Thanks everyone, both answers make sense but I have left it off and the clock is working fine. It's not moving again so I am certainly not taking the movement out.
19,579
4,633
I wouldn't either ...
It's rare for these springs to be damaged though. So, that clock's pendulum assembly really took a beating.
wow
Jun 24, 2008
7,739
1,765
78
Mark Butterworth says it is there to protect the SS from the customer. It keeps the leader from being pushed up and coming off of the SS. It is also a shipping protection thing.
NEW65
Nov 17, 2010
1,983
190
United Kingdom
It's there not just for protection of the spring and to prevent the leader from becoming detached from the spring, but to keep the spring tight in the chops when the retaining screw is tightened. It's absolutely essential that the spring is tight in the chops to avoid wobble of the heavy lyre pendulums that are supplied with HM clocks.
183,860
1,605,833
55,918
Haydee
3,190
Watch case by Kent
Top Bottom
