How to?
Discussion in 'Clock Repair' started by Grant1, Sep 13, 2017.
  1. Grant1
    Grant1 New Member
    Sep 13, 2017
    NC
    Click spring broken in two grandfather movements.
    1161-853 BS time cable barrel
    And a Howard Miller
    AJK 06k chime cable barrel
    My question is how do I get these barrels out
    Of the movements in order to repair click springs.
    Thanks for your help. This is my first post.
    I hope I covered everything.
  2. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    737
    Science teacher, writer
    Lancaster, Ohio, USA
    Please send in a photograph of the front of the movement so we can have a look.
    Some of these movements allow you to remove the ring that holds down the ratchet wheel, and then the ratchet wheel itself, and then the winding arbor itself. After that the cable barrel, or whatever it's called, will drop out from between the plates.
    Otherwise, you'll have to disassemble the movement to get the barrel out.
    I wonder what damaged the click springs.
    M Kinsler
  3. kinsler33
    Aug 17, 2014
    737
    Okay. Grant1 didn't quite understand the procedure here and thus sent his movement photographs to me instead of the forum. So I've posted them here.
    Looks like one of these has extractable cable barrels, or whatever they're called, but I don't know about the other even though it has those limiting gears on the front. (I clearly don't know what they're called, either--they're not Geneva's)
    Never found a bad click spring in one of these, but Timesavers sells them, so I guess they fail.
    M Kinsler
  4. Grant1
    Grant1 New Member
    Sep 13, 2017
    NC
    Thanks Mark for all your help.
  5. Willie X
    Willie X Registered User
    8,148
    32
    The cable drums can be removed from the Hermle 1161 by removing the "E" clip on the back end of the winding arbor.
    The H-M/Kieninger will have to be taken apart.
    It's best to replace the complete cable drum assembly, if available.
  6. MARK A. BUTTERWORTH
    MARK A. BUTTERWORTH Registered User
    NAWCC Member Donor
    Jul 4, 2009
    1,882
    Diistributor of movements and movement parts.
    Muscatine, Iowa 52761
    We carry them.
  7. Grant1
    Grant1 New Member
    Sep 13, 2017
    NC
    Thanks Willy, I currently order all my parts and
    new movements from Butterworth. I appreciate your help.
