How to wind Self winding clock company clock
Discussion in 'Electric Horology' started by pvjones, Apr 28, 2017.
  1. pvjones
    pvjones New Member
    Apr 28, 2017
    First, I don't know anything about clocks, but came into a SWC of NY clock. It is round, looks industrial, with bubble glass and is approximately 18" (face) in diameter roughly 19.5 in overall.
    Questions 1: how do I determine what model it is?
    Question 2: Is there a way I can start this clock prior to spending a bunch of money replacing the 1.5V original batteries, to determine if it will even run?
  2. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,865
    watchmaker
    Western NSW, Australia
    How many batteries does it use?
  3. lmester
    lmester Registered User
    Dec 30, 2009
    442
    I manage HVAC systems for a school district.
    West Virginia
    You can manually wind a SWCC. clock. For the common type F movement, just manually move the winding motor armature up and down. Below is a video of me manually winding one. In this video, the motor coils are not yet installed. You'll only see the armature. The empty space below, where my finger is moving the armature, is where the two coils are normally mounted.
    https://www.youtube.com/edit?o=U&video_id=OA11jzMJeCY
    Please post some pictures of the clock movement. I'll then know for sure what type of clock that you have and can give you more detailed information on how to manually wind it.
    Also, you could just use some jumper wires to connect a pair of fresh batteries. A SWCC clock usually uses two 1.5V batteries connected in series. Any type of 1.5V battery will work for testing. AA, C or D. There should be a manual wind switch inside the clock case. You may need to push this to start it winding. Release it once it keeps winding on it's own.
    Again, Pictures of your clock will help.
  4. lmester
    Dec 30, 2009
    442
    West Virginia
  5. Frank Manning
    Frank Manning Registered User
    Nov 22, 2005
    336
    Vernon, CT
    You don't need to spend a lot of money to replace the old style batteries as Imester mentioned. I use 2 D size cells in one of those plastic battery holders. If the clock is in decent condition they will last mostly a year.
    If you take the dial off you can reach in on the lower right side and manually turn the winding gear to see if it will run.
    Frank
Similar Threads - wind Self winding Forum Date
International self wind clock: why are the coils too weak to impulse? Electric Horology Feb 2, 2012
German self-wind Master Clock - ?help? Electric Horology Nov 13, 2009
self wind Western Union Electric Horology Jun 6, 2009
Case for a Seth Thomas Self Wind A Electric Horology Jun 29, 2008
Haupuhr Self-Wind Electric Horology Jun 6, 2005
