How to set out a verge escapement for an English bracket clock
Discussion in 'Clock Repair' started by NigelW, Mar 29, 2019.
  2. Our Donation Service is back after a brief absence to fix the payment service. Please give it a try! Donate
  1. NigelW
    NigelW Registered User
    Jan 2, 2015
    163
    11
    London
    I would appreciate any guidance on how to set out a verge escapement for an English bracket clock. My copy of Gazeley, which is normally good on these things, isn't very helpful.
  2. wow
    wow Registered User
    Jun 24, 2008
    3,077
    90
    Retired Music Minister
    Pineville, La. (central La.)
    Nigel, please explain in more detail what you need help with. Also, please include photos.
  3. novicetimekeeper
    Jul 26, 2015
    7,986
    272
    Dorset
    Peter Hageman has done a successful reconversion (PHageman) You might want to look up his thread and speak to him. He also casts his own yellow brass blocks and does his own engraving!
  4. D.th.munroe
    D.th.munroe Registered User
    Feb 15, 2018
    152
    26
    Horologist
    BC Canada
    #4 D.th.munroe, Mar 29, 2019
    I don't know if it would help, I'm not sure how much changed in 50 or 60 years, but I have an un-converted (original) later 1700s verge I could take pictures or measurements. I guess measurements might not help though.
    Dan.
  5. NigelW
    Jan 2, 2015
    163
    11
    London
    My clock would originally have had two verges: one for the going train and another for the alarm. Both are missing but I am close to deriving their likely diameter and tooth count. I am currently modelling the missing parts in a CAD programme (progress is being documented here: 1710 Etherington Table clock with lots of bits missing ) but to finish the design I need to lay out the pallets in relation to the crown wheel and make sure I have the geometry right. My understanding is that crown wheels in these types of clocks did not have undercut teeth but I am not sure either of the shape of the curve on the crown wheel nor the pallet length and the distance of its arbor from the top of the crown wheel teeth.
  6. D.th.munroe
    Feb 15, 2018
    152
    26
    Horologist
    BC Canada
    I do have books on this somewhere. I think shorter pendulum clocks a rake or undercut on the teeth isn't necessary. And the curve is irrelevant as long as the pallet flags dont hit them after the drop off. usually the pallet angles for english brakets was between 90 and 110 degrees. The height of the pallet arbor from the crown and length of the pallets is a bit harder though, cad may help, depending on the tooth counts and the wanted arc of the pendulum. I know the first pallet should just escape as the point of the opposite tooth touches the opposite pallet.
  7. Willie X
    Willie X Registered User
    10,569
    350
    John Plews covers this subject well. His book is big on making parts for old English clocks. Willie X
  8. NigelW
    Jan 2, 2015
    163
    11
    London
    I am not familiar with this book and an author search on www.bookfinder.com yielded no horological titles for John Plews, or anyone with that surname. Is it very rare, or am I looking in the wrong place?
  9. gmorse
    gmorse Registered User
    9,543
    712
    Retired from Xerox
    Hi Nigel,
    I just sent you a conversation. I recall an AHS lecture some years ago by Roger Still, (a tutor at West Dean and senior restorer at Carter Marsh in Winchester, who restored the Scott-Cumberland Tompion), who maintained, if I remember correctly, that the ideal flag angle for English verge table clocks was in the region of 70º to 80º, and not the commonly accepted but higher range, (which is perfectly valid in watches).
  10. wow
    wow Registered User
    Jun 24, 2008
    3,077
    90
  11. D.th.munroe
    Feb 15, 2018
    152
    26
    Horologist
    BC Canada
    Ah sorry for the bad info. I have wondered about the angles and that, authors have differing theories, those just came from Laurie Penman's Practical Clock Escapments
    I think I'd trust Roger Still more though.
  12. NigelW
    Jan 2, 2015
    163
    11
    London
    I found a copy of Penman's book in my clock club's library. It is very helpful but he does not give much in the way of detailed data on specific clocks and their pallet angles. I think it gives me enough to go on for the time being however.
  13. Willie X
    10,569
    350
    Nigel,
    The Plewes book is a great book to have in your library but it does NOT cover crown wheel escapements. His book is dedicated to pendulum clocks only, from 1700 to 1940. Published by Sterling Publishing Co. Inc. New York 1984,
    Penman has about 38 pages dedicated to the subject and is the best source of info I have in my library.
    Sorry for the mixup. Willie
  14. D.th.munroe
    Feb 15, 2018
    152
    26
    Horologist
    BC Canada
    In Penman's "The Clock Repairer's Handbook" he has 1 more sentence on the angles of the verges.
    "Verges made before the middle of the 18th century have a wide angle between the two impulse faces of around 110 degrees; more recent verges often have a smaller angle of between 60 and 80 degrees."
  15. Willie X
    10,569
    350
    The Plewes book title is, 'Repairing and Restoring Pendulum Clocks'. Willie X
  16. novicetimekeeper
    Jul 26, 2015
    7,986
    272
    Dorset
    This is a pendulum clock, in the first form of pendulum clock. Does he just start at anchor?
  17. D.th.munroe
    Feb 15, 2018
    152
    26
    Horologist
    BC Canada
    Seems odd he would exclude the crown wheel.
    This made me curious for myself about the angles of the one I have.
    It's in pretty bad shape and later but still. Pretty sure thats a french crutch on a London clock. lol
    The backs of the flags on this are 110 degrees but the working face is 80 degrees.
  18. DeanT
    DeanT Registered User
    Mar 22, 2009
    808
    51
    Australia
    Somewhere I have some notes about the geometry of the verge setup. Will see if I can find them.
    Do you have access to an example to follow? I might be able to photo and measure one which is a similar age if that is required.
    Cheers
