Happy New Year to all!
Pictured is a pendulum rod from a Waterbury hanging long drop clock. The spring is broken. It appears that to replace the spring, the top of the rod needs to be straightened, the bit of the broken spring removed, new spring inserted, the rod bent to original shape.
What is the best proceedure for bending the rod? The steel is pretty tight. I don't think needlenose pliers will cut it. How would the pros do the replacement? I would like to know what tools would be best to use.
I would also be thankful for any info. on what is the correct size replacement spring. The movement plate is stamped "16", but the total length of the pendulum is 18 3/4" (from the top of the loop pictured, to the bottom of the threaded post where the pendulm regulating nut is on).
Thank you for any help. I appreciate it.
