How to repaint the numbers on a brass clock dial
Gage_robertson_collector
May 4, 2021
42
7
Hello, I was just curious which paint and/or which technique i should use to go about repainting the numbers on this 1893 seth thomas mantel clock i have. The numbers were originally black. I thought about using a paint sharpie (the one where you shake it up and actual paint comes out of the tip) mostly because of the convenience it would be to apply it using this technique,
but i wasnt sure if that was the best route as i would like it to be relatively durable and as close to original as possible.
thanks,
- Gage robertson
bruce linde
ADMIN / MODERATOR
8,872
1,378
oakland, ca.
clockhappy.com
i have one of those sharpies and half the time i get big globs rather than controlled output....
if it were me i'd pull the dial for best accesss and make sure i had plenty of good lighting and magnification... and go really slowly using very small paint brushes (after making sure there's no oil or anything on the surfaces).
also... i was able to restore the fine gold lines on this one using an extra fine tip sharpie and carefully wiping off any that went outside of the recesses using a lint-free wipe and some alcohol.... maybe not the best job, but looks great from more than a couple of feet away... :)
May 4, 2021
42
7
Looks great! Actually I was already planning on repairing those details using pen ink, using a technique that was suggested to me in another thread. Either way, thanks for your input on the numbers!!
- Gage
May 4, 2021
42
7
thanks for your advice!! I actually ended up using gold pen ink on a clock oil applicator to get the color back on the face there. I think it looks pretty good!! Still have to do the numbers though!!
- Gage
Reactions: Dave T
bruce linde
ADMIN / MODERATOR
8,872
1,378
oakland, ca.
clockhappy.com
it occurred to me that you could fill in the circles around the numbers with a sharpie and it might look pretty good.... here's a quick-and-dirty photoshop using a dark brown....
Reactions: T.Cu and Dave T
167,149
1,456,527
87,339
jtc52
