I just acquired a tambour clock with a broken strike spring. In the pic below you can see that the free end of the broken spring is jammed up against the bottom of the case. The coil has expanded to it is also jammed up against the side of the case (at the green arrow).
Any advice about how to safely remove the movement from the case. My guess is that if I just remove the movement mounting screws the spring will just expand and could do so dangerously. I assume I need to find a way to hold the spring from further unwinding. Cable tie around the spring ? Will that be safe? Someone must have experience with this kind of thing who can advise how to do it safely.
