Hopefully, I have this in the correct forum, rather than General Clock Discussion.
Please see the photograph of a small French mantle clock, timepiece only. I am trying to remove the brass housing from the wooden case without doing further damage. It came to me partially mangled and I do not wish to add to its woe.
I have tried freezing it overnight at minus 28 degrees centigrade. When that failed, I blasted it with a very warm flow of air from a hairdryer for several minutes and it simply will not budge. I suspect it to be circa 1920. I have considered cutting the metal and silver soldering or brazing later but before I do something as drastic as that I am hoping someone has the "right" solution.
The movement is in tip-top condition so if all else fails I can look out for a suitable case. Thank You. Kieran
