• Upcoming updates
How to lay out the winding arbor holes on a new dial?
Keith Doster
Mar 31, 2011
445
85
67
Chester SC
I'm working on a large two-sided Seth Thomas clock that mounts perpendicular to the wall. It would have been used on a train station platform or in a school hallway. I acquired the movement and hands several years ago, and a very talented friend created a custom case for it. Now to make the dials. I am having some thin sheet steel cut to fit the case and intend to use paper dials on the steel. One side of the movement has the two winding arbors. What would be the best way to drill accurate holes for the winding arbors? I don't want to have to do this twice. The steel sheet/dial is square, so that will probably simplify things somewhat. Any advice would be appreciated. A video might be even more appreciated! I'm sure this isn't as complicated as I envision it to be. Thanks!!
49,729
3,040
Make yourself a preacher. But an easier way might be to use the front plate of the movement as a stencil. You'd just have to find the center of the dial for the initial positioning of the center hole.
Keith Doster
Mar 31, 2011
445
85
67
Chester SC
Using the front plate sounds like a great idea. I knew there had to be some, relatively easy way to do this. That is a big help. Finding the center for the minute arbor shouldn't be a big deal.
5,782
993
You can also take a sheet of paper or thin cardboard with the dimensions of you dials. Punch a hole in the middle with a diameter of the hour cannon. Put that sheet on the front of the clock with the hour cannon inside the hole. Mark the position of the winding arbors. Now you have a template for drilling your holes.
Keith Doster
Mar 31, 2011
445
85
67
Chester SC
I had to read it a couple of times to understand what you were suggesting, but that is also an excellent idea. I may need to post some pictures of this process when I get around to it. Thanks for the advice!
18,286
3,676
A large machinist compass (not a drafting compass) and a vernier caliper can get you there in just a few steps.
Using the front plate is by far the easiest but to do this effectively you have to have a bare front plate. Something that may not be practical.
JimmyOz
Feb 21, 2008
1,372
474
67
Gold Coast Qld
I think using the back plate would work and no need for much dismantling. Put a X from corner to corner on your sheet, drill a hole the same size as the hands arbour pivot and put a stiff wire through the plate pivot hole and through the sheet, now mark the winding arbour holes, making sure the plate is 90 degrees to the edge of the sheet. This is saying the sheet is square though.
JimmyOz
Feb 21, 2008
1,372
474
67
Gold Coast Qld
Okay I just read the OP post again it is a 2 sided movement, however it may still work?
Reactions: Keith Doster
Keith Doster
Mar 31, 2011
445
85
67
Chester SC
JimmyOz, thankfully, the other side of the clock has no winding arbors, just a center hole for the minute arbor. No seconds bit. Piece of cake!
Mike Phelan
Dec 17, 2003
11,131
430
West Yorkshire, England
I've always used Uhralt's way with a thin card.
180,087
1,571,001
54,369
wbaNev
911
3,102
