How to fab up a suspension wire with a half circle to clear hour pipe
John P
Sep 17, 2010
1,017
68
73
Every now and then I must make up a new suspension wire that bends to clear a hour pipe.
I usually mess up one or two wires before I get right, and was hoping you guys might give me a tip, or explain your method.
RJSoftware
Apr 15, 2005
8,416
95
Loxahatchee, Florida
Hey David S. Curious about the terminology. I was/am under impression that the latter object/tool is called a "wire jig" but notice you call it a Jib. Just curious.
BLKBEARD
Nov 15, 2016
759
24
CT
sailorsandsettlersantiques.com
Probably just a Typo, since the letter "B" & the Letter "G" touch each other on a Keyboard
And since David took the time to post pictures of his tools & method, whether you call it a Jib, a Jig, or a Bench Mount Adjustable Bending Fixture, I think everyone can see the Tool & it's Usefulness.
RJSoftware
Apr 15, 2005
8,416
95
I look for advantages like this in ebay searching of tools. One man's jib is another man's jig. :)
12,774
987
A sharpie mark where the top of the loop needs to be. Make a sharp right angle bend here using regular pliers. Then clamp a length of 5/8" or 3/4" round stock in your vise and make the loop. Then figure out where the second right angle bend needs to be. Finally, true up your loop, so that when you sight down the wire the straight part below the loop is exactly in line with the straight part above the loop.
Usually the loop is slightly more than a half circle, sort of a "D" shape but I have found that half circle is plenty big in nearly all cases.
44,321
1,354
For technique, leave the wire straight, and mark the center where it touches the hour cannon. Then clamp a 1/2" gas pipe or similar hard cylinder into your bench vise and center your mark in the center of it. Make your bend, then touch up the upper and lower parts back to straight lines with pliers, a wire bender, or whatever you have. I see I missed posting before Willie. I forgot to save it, and had to use the auto restore feature. For smaller bends, use a smaller pipe :)
12,774
987
Bugs, make your mark at the top, where you want the loop to start. If you center your loop on a mark at the cannon, your loop will end up to high.
Loop on, Willie X
44,321
1,354
Loop on, Willie X
The center of the loop will be the center of mark, Willie.
David S
Dec 18, 2011
7,205
248
Brockville, On Canada
Shutterbug I think Willie is saying that your method doesn't allow for the extra circumference that is generated by bending a larger circle around the arbor. If I am understanding..perhaps not.
David
44,321
1,354
I think Willie just likes to make the 90° bend first, then the loop. With that method, he's correct. I make the loop bend first, then the 90° bends afterward. Same result, different approach :)
gleber
Jun 15, 2015
1,907
240
Downingtown, Pennsylvania USA
www.myclocks.site
Shutterbug - If you mark the wire even with the hour cannon, that is the shortest distance being a straight line. So, if you bend the wire so the mark is in the center of the loop it can no longer be even with the hour cannon since it now follows a crooked path. It would end up higher and no longer even with the hour cannon. I think something is missing in your explanation...? The mark would have to be placed lower than the hour cannon to account for the longer distance of the loop. The question then becomes how much lower should you place the mark?
Tom
44,321
1,354
I think I see what you're saying, gleber. The bend subtracts length from the total length of the suspension, so the feather would have to be lengthened to make it work. I'm sure there's a math formula there somehow. I have made those things, but don't remember if I had failures in the process. I'll ponder it some more. In the meantime, I retract my advise and bow to what Willie (and you) have advised.
Topic related ad experiment
160,944
1,396,208
82,924
waynebernelli
1,099
2,788
