How to Add a Picture from your PC or Laptop (revised)
Status
Not open for further replies.
bangster
19,940
459
IMPORTANT NOTE:
Please do NOT upload links to pictures not on the Message Board
You must upload the actual picture from its source, not a link to a photoservice
or other storage unit..
ADDING A PICTURE TO A "QUICK REPLY"
In Quick Reply window, click Insert Image button.
An Insert Image window will open. Click on Select Files button.
Note that only .jpg .jpeg .png and .gif files may be uploaded by this method
A Getfile window will open, showing files on your computer. Browse your computer and select files to upload. Click Open.
The selected files will appear in the Insert Image window. Click the Upload Files button.
The files will appear in the Quick Reply window, attached and ready to go, as Thumbnails that will expand in the posted reply.
To edit the alignment and size of the image, double click on the image. An Image Settings window will open. Choose the alignment & size you want, and click OK.
NOTE: If you can, make sure that your pic is oriented correctly (right-side up instead of sideways) before you send it. If it isn't the Message Board software can't rotate it for you.
If you get a message that your pic can't be uploaded, it will almost always be for one of two reasons: Either it isn't an allowed file type, or it exceeds the allowed size limit for that type. (See chart next page.) Size limits have recently been increased for some types, to reduce problems of that kind.
Reactions: MDean
bangster
19,940
459
How to Add a Picture from your PC or Laptop or iPad
IMPORTANT NOTE:
You must upload the actual picture from its source, not a link to wherever it is located.
Here are the permissible types and sizes of files that may be uploaded. Tnx gregoryjohn for the suggestion to include this.
If you get a message that your pic can't be uploaded, it will almost always be for one of two reasons: Either it isn't an allowed file type, or it exceeds the allowed size limit for that type. Size limits have recently been increased for some types, to reduce problems of that kind.
bangster
19,940
459
How to Add a Picture from your PC or Laptop or iPad (revised)
IMPORTANT NOTE:
bangster
19,940
459
How to Add a Picture followup draft broken
IMPORTANT NOTE:
bangster
19,940
459
Update: Adding a Picture from your PC or Laptop
IMPORTANT NOTE:
TO ADD A PICTURE TO A NEW MESSAGE OR AN ADVANCED REPLY:
Click on the Paperclip icon in the menu bar of the message window (editing window).
A Picture Window & Attachments Window will open. If this is the first picture you have ever uploaded, the Picture Window will be empty. Otherwise it will show all of your previous uploads. Click on the Add Files button.
The Add Files Window will open. Click on the Select Files button.
A Getfile window will open, showing files on your computer. Browse your computer and select the files you wish to upload. Click Open.
Their names will show up in the Add File Window. Click the Upload Files button
The upload will take place. The uploaded file will appear in the Picture Window and in the Attachment Window. "Selected" files in the Attachment Window are the ones ready to be attached to your message. Selected files are blue. If there are other files in the Picture Window you wish to attach, drag them to the Attachment Window and Select them (click on them) if they're not blue.
Go to the Message Window. Pull down the menu from the Paperclip icon. It will show the names of all the files in the Attachment Window. Click on the ones you wish to attach.
The attached file will appear in the Message Window, located at the insertion point, as a Thumbnail that will expand when clicked in the posted message.
To edit the size and location of the file that will appear, double-click on the image in the Message Window. An Image Settings window will open. Choose the alignment and size you wish to have, and click OK.
Here are the file types that may be uploaded, and their size limits.
NOTE: If you can, make sure that your pic is oriented correctly (right-side up instead of sideways) before you send it. If it isn't, the Message Board software can't rotate it for you.
bangster
19,940
459
IMPORTANT NOTE:
bangster
19,940
459
IMPORTANT NOTE:
bangster
19,940
459
IMPORTANT NOTE:
bangster
19,940
459
Adding Attachments to Posts
Advanced Information on Adding Attachments to Posts
TO CHANGE THE SIZE OR ALIGNMENT OF A PICTURE:
Here's what you'll see to start with.
Click on the picture to bring up this window:
Set the radio buttons for alignment and size, and click OK. You only get this when you are in Edit mode
ATTACHING DOCUMENTS BESIDES PICTURES.
When in Advanced mode, you can attach more documents than just pictures (pdfs, docs, etc.) by using the Paperclip.
The upload will take place. The uploaded file will appear in the Picture Window and in the Attachment Window. "Selected" files in the Attachment Window are the ones ready to be attached to your message. To select a file, drag it into lower Attachment Window. Click on the check box lower right. If there are other files in the Picture Window you wish to attach, drag them to the Attachment Window and Select them (click on them).
You can edit the size and location as described above.
Here are the file types that may be uploaded. Disregard the "Max File Size" column. It has been superseded by much larger numbers.
Make sure that your pic is oriented correctly (right-side up instead of sideways) before you send it. If it isn't, the Message Board software can't rotate it for you.
bangster
19,940
459
Advanced
bangster
19,940
459
Advanced
harold bain
40,853
175
72
How the rack and snail strike works
Here is a link to Bangster's encyclopedia article on Rack and Snail strikes: Rack Strike Elements
bearzworkshop
Dec 1, 2011
97
Count Wheel Movement, Annotated
cal clock front annotated.jpg ================================================================================================
bangster
19,940
459
List of Topics Referenced Above
added:
All About Shellac
bangster
19,940
459
FAQ's
Click Here to go to the "Hints & How-To's" forum & find many answers to your questions.
CLICK TO ENLARGE
bangster
19,940
459
All About Pendulums
EVERYTHING YOU EVER WANTED TO KNOW ABOUT PENDULUMS
ABOUT PENDULUMS.pdf
View attachment ABOUT PENDULUMS.fix+.pdf
CONICAL PENDULUMS.pdf..............................................................................................................TORSION PENDULUMS.pdf
View attachment ABOUT TORSION PENDULUMS.pdf View attachment Conical pendulums-a.pdf
THE SWING-ARM PENDULUM.pdf...............................................................................................................................PENDULUM FORMULAE.pdf
View attachment SOME EQUATIONS.pdf
bangster
19,940
459
shimmystep
Mar 5, 2012
4,105
82
Cambridge, UK
How to make a dovetail for replacing a wheel tooth
Following a recent thread on wheel tooth repair I thought it might be useful, and enjoyable, to show a few techniques I use when repairing/dovetailing a tooth on a French wheel. These teeth are very small and can be challenging to replace. I've enjoyed doing this, I hope it offers something to someone, maybe a useful sticky in repairs?
I have used a French wheel from my parts bin.
The tooth in question can clearly seen to be bent in Pic 1. Before the tooth is removed, using a sharp scribe, score a line from the centre of the base of the old tooth on the radial line to centre of the wheel, no deeper than half the depth of the rim, pic 2. Once this is scribed the tooth can be carefully taken off using a very fine blade on a jewellers scroll saw; fine enough to fit between the teeth and cut along the line of the wheel circumference.
Using the scroll jaw, cut into the wheel along the scribed radial line to the desired depth, pic 3. Avoid cutting deeper than half of the depth of the wheel rim. When using a scroll saw for these micro jobs I have found the scroll saw easier to use and control if only approx a quarter of a blade is used.
Use the scroll saw to carefully cut the dovetail sides, to the same depth as the centre line already cut, pic 4. The scroll saw can be carefully used to remove any brass in the dovetail hole. Using a very thin cut of 600 grit wet and dry cloth in a ‘to and fro’ motion with both hands will effectively smooth the base of the dovetail, pic 5. Wet and dry paper will break doing this, the fibre backed type is ideal for this.
Finishing or widening the dovetail side is tricky in such a tiny space. My preference here is too use the cheap Indian suspension springs with wet and dry paper glued to one side, pic 6. This technique creates a tool that can work effectively in this small space and also will not abrade other areas of the working space, pic 7.
Once you’re happy with your dovetail hole, pic 8, cut a piece of donor brass, place it under the dovetail hole, mask the wheel up with tape; holding the donor piece tight to the wheel with the tape, pic 9. Spray the dovetail very lightly with an aerosol paint and leave to dry. Any paint on the wheel will dissolve in some acetone, and you will have the impression of the dovetail left on the donor brass, pic 10, which will be a great help when cutting the new tooth/dovetail insert with the scroll saw. Leave plenty of brass at the large end of the donor piece for handling and holding in a vice, pic 11. It will also be a lot easier to find if you drop it, or subconsciously put it down on the bench whilst looking for a different tool.
The donor piece needs to be a tight fit. It is a good idea, with a very fine paint brush , to apply a little solder flux in the joint before fitting. I use Tix flux and solder.
When you are happy that it will go in with a little gentle persuasion, I have found the best way is using a staking tool and a small piece of ‘Bluetac’, pic 12, a little tap with a brass ended flat punch will fit the piece squarely. Ensure there is excess donor brass either side of the wheel, and using a steel flat punch in the staking tool, ‘peen’ the donor brass to fit/fill the dovetail hole well, pic 13. This is why the flux has already been applied in the joint.
Only very tiny chips of solder are needed for the joint, It is helpful to squash the solder in smooth nose pliers, cut teeth longways and then trim tiny pieces off and place them on the seams on the joint, pic 14. This needs doing under mag, I use 10x for this as I like to have the solder pieces ‘standing up’ as in the picture. Placing the solder in this way I find that the solder, melts, drops and flows straight into the joint and much less on the wheel rim, pic 15/16.
A mini butane soldering torch with a fine hot air nozzle attachment, to ensure there is no flame, and at a low/med heat from underneath does a great job. Some prefer other heat sources, including alcohol lamps. After it has cooled clean off any flux thoroughly.
I prefer to leave a ‘long tooth’ throughout, up until the next stage, as it is easier to see that the new tooth is still on the radial line. When cutting off the excess tooth, and filing to length it is a good idea to protect the adjacent teeth tips with tape, and keep checking it has not been breached, pic 17 .
If the gaps between the new tooth and adjacent teeth has been compromised, by solder for example, it can be very tricky to ‘make good’ in such a small gap. Get another of those cheap Indian suspension springs, put it in the vice, and ‘skip’ a needle file across its edge to give it very fine teeth, pic 18. Using this will make a good job of re-defining the 90deg root angle of the tooth in the gap, where most files will not fit, pic 19.
If the new tooth is too wide, use the suspension spring with the wet and dry paper stuck to it to reduce its width. Again, using this will ensure only the width is abraded, not the gaps base. These can also be used to finely finish the tooth’s profile. Carefully remove excess brass from the tooth to match the wheel rim width, with damaging/marking the rim. The dovetail can be carefully finished/polished with very fine wet and dry paper, to a point where it is virtually invisible to the naked eye.
When using files to shape the tooth, it is best to use as fine a file as you can, cut grade 4 and above. ‘Escapement’ files are smaller than other needle files, for shaping the top of the tooth a Barette/safety escapement file is ideal. Good ones are not cheap, and should be saved for delicate jobs.
bangster
19,940
459
bangster
19,940
459
Members' Pictures (Merged Threads)
Earlier pics of a lot of MB'ers. (LINK).
Thanks to P.Lee for tracking it down.
I have merged the old and new threads.
bangster
moderator
1/10/14
Walt Wallgren
Aug 16, 2012
1,209
29
Bay Area, California
Re: Vintage Thread: "Your Pic Please"
I jumped in. Do we want to continue the old one of start fresh here. If we want to start fresh, please feel free to move my post here.
Thanks,
Walt
bangster
19,940
459
I think we'll keep this one as is.
46,162
1,768
As the one fills up with new members who are not shown in the old one, we can eventually merge the two into one. When we do that, we should clean it up so only the pics show.
bangster
19,940
459
Re: Hall of Shame Link
I have added instructions to the original post, for those unfamiliar with links.
bangster
moderator
bangster
19,940
459
Re: Bang,s tutorial on re holing a main spring.
sequence
bangster
19,940
459
Re: Disassembling an American Time & Strike Movement
sequence
Bill Stuntz
Apr 6, 2012
4,775
20
72
Columbus. OH
How to Add a Picture from your PC or Laptop (ii)
ADDING A PICTURE WITH THE "INSERT IMAGE" BUTTON
If possible, please avoid uploading URL links to pictures not on the Message Board. Please upload the actual picture from its source, not a link to a photo service or other storage unit. That way it will remain with the Message Board even if the storage unit crashes or goes out of business.
Please be sure that your picture is oriented correctly (right-side up instead of sideways) before you upload it.
The Message Board software will not rotate it for you.
In Message window, click Insert Image button in tool bar. (Looks like a camera.)
Note that only .jpg .jpeg .png and .gif files may be uploaded via the Insert Image button. Maximum uploadable
photo dimensions: 5200x5200 pixels.
The names of the selected files will appear in the Insert Image window. Put the insertion point cursor where
you want the pictures to go. Click the Upload Files button.
The pictures will appear in the Message window at the insertion point of the cursor, attached and ready to go.
Bill Stuntz
Apr 6, 2012
4,775
20
72
Columbus. OH
Basic
KLS
Apr 18, 2014
64
62
Netherlands
Disassembling a Two-Train Movement
These pictures show the step-by-step disassembly of a Hermle 261-080 two-train weight driven movement. They were posted by Klaas in This Thread.
They are copied here, with his permission, as a visual tutorial, both of how to disassemble a movement and how to take a thorough series of pictures for later reference.
:coolsign:
bangster
moderator
First Group in a series of Four
230637.jpg 230638.jpg 230639.jpg 230640.jpg 230641.jpg 230642.jpg 230643.jpg 230644.jpg 230645.jpg 230646.jpg
KLS
Apr 18, 2014
64
62
Netherlands
Re: Fhs 261-080
:coolsign:
bangster
moderator
First in a series of Four groups
KLS
Apr 18, 2014
64
62
Netherlands
Re: Fhs 261-080
Third group in a series of Four
230657.jpg 230658.jpg 230659.jpg 230660.jpg 230661.jpg 230662.jpg 230663.jpg 230664.jpg 230665.jpg 230666.jpg
Status
164,810
1,434,002
85,813
objectsnthemirror
2,863
