My 645 movement has the barrel type that does not seem to have a removable arbor. Is there a way to remove the arbor so the mainspring can be serviced?
This jeweled barrel screws together. Put the ratchet wheel back on the arbor with the screw. Then grasp the barrel with one hand and unscrew the arbor by grasping and turning the ratchet wheel.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
