Try to leave a small end with the T sticking out of the winder and carefully try to stick it in the hole. I have found that if close, you can use a screwdriver to push the T end around a small distance and get it in the hole if you miss.
Thanks for the replies!
I have tried these methods and end up with the lower T end just missing the hole in the barrel. Right now I have a new mainspring in a barrel that just missed the hole. I have tried using tweezers to slide the T back to the hole, but it doesn’t move. I will try using a screw driver.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
