How in the world? (Swiss hairspring removal)
jplotkin
May 8, 2016
115
Philadelphia, PA
How in the world do I remove the hairspring and balance wheel from this swiss balance cock?
I'd like to clean remove the balance wheel entirely so that I can clean the top jewels and re-oil. But there is no screw or hairspring stud that holds the hairspring into the cock. So how do I remove?
The cock assembly has a nice regulator pin that can conveniently be opened by screwing -- but apparently no convenient way to remove the balance wheel with hairspring:???:
Photos of the mystery attached.
svenedin
Jan 28, 2010
1,263
234
Surrey
You have to unpin the balance spring from the balance cock. I personally find that a difficult task and I have wrecked a hairspring at the re-fitting stage before. You would need to mark the hairspring so that it can be re-pinned at the same length.
jplotkin
May 8, 2016
115
Philadelphia, PA
You mean I have to push out that brass pin (in the downward/left direction in the second photo)? And then push it back in to clamp hairspring back in place, after cleaning?
How horrid! What a terrible operation.
Would I use tweezers to do this? And why is there a groove in the stud that holds the hairspring and pin?
EDIT: OK, I tried this with tweezer, and the pin moved pretty easily actually. Still seems horrid.
svenedin
Jan 28, 2010
1,263
234
Surrey
Yes it’s a tapered pin. It is horrid, it’s a very small pin! Let the professionals tell you how to do this safely. Don’t ask me!
D.th.munroe
Feb 15, 2018
932
309
39
BC Canada
On most of these you can actually push the pinning block out from the top (the pin you see above it on the cock) without unpinning the hairspring itself.
There used to be special tweezers with a 90° pin on side and a fork to support around the pinning block on the other for this.
The pin is just a friction fit in the cock, so after cleaning just push it back in and use the slot in it to turn it to the right place if it's not correct.
Dan
gmorse
12,528
2,158
Hi J,
When you do it correctly, as Dan has suggested, you must be very careful if you don't have the special tweezers, since it's easy to slip and damage the balance spring. If it won't pop out easily, try turning it slightly from side to side first.
jplotkin
May 8, 2016
115
Philadelphia, PA
Lacking the specialized tool do you recommend removing entire pinning block from cock or just pushing out pin? Pin seems to move pretty easily I’ve already found (under scope for observation).
Thanks for advice as usual.
jplotkin
May 8, 2016
115
Philadelphia, PA
Operation completely successful (photos below). Pin was quite easy to remove, and hairspring threaded out through hole easily enough. Balance assembly now cleaned, oiled, reassembled, running at about -1s/d after regulation.
Thanks for all your advice again!
gmorse
12,528
2,158
Hi J,
Ideally, that pin would have a flat filed on the side nearest the spring, making it D sectioned, so that there's less tendency for the spring to be 'cupped' when the pin is driven home. It also makes it easier to turn the pin and spring together to bring it level.
Reactions: jplotkin and Al J
166,251
1,448,536
86,766
Dmvalente
2,910
