How heavy the weights?
Discussion in 'General Clock Discussions' started by lxt123, Nov 16, 2018.
  1. lxt123
    lxt123 Registered User
    Apr 13, 2010
    22
    I got this clock without any weight. It is a very narrow channel for them, I'm thinking that the weight is rectangular shaped.
    Any idea about how heavy should be?
  2. Willie X
    Willie X Registered User
    12,774
    985
    #2 Willie X, Nov 16, 2018
    lxt,
    I have never seen one made like that. My guess would be that the designer wanted the weights to be always visible so you can see if and when it needs winding? I would think gold painted weights with a square or rectangular cross section, to loosely fit the available space, would be nice. 2 1/2# lead would be a good place to start. Someone may have a clock like yours, or a photo to give you a guide to go by. Willie X
  3. claussclocks
    claussclocks Registered User
    Mar 14, 2013
    868
    275
    Texas
    Can you tell if it's a 30 hour or 8 day? Seth Thomas made a small shelf clock with an 8 day movement that required 6lb weights that were rectangular and had a notch in the side facing the movement to allow for the cable to not rub the weight when fully wound. I have a customer who owns one and I ended up making round weights that were a little too long because no one had a weight the size that clock takes.
  4. Willie X
    12,774
    985
    My money is on a 1-Day, or 30 Hour.
  5. lxt123
    Apr 13, 2010
    22
    When the door is closed, the weights are partially hidden.
  6. lxt123
    Apr 13, 2010
    22
    Looks like an 30hrs movement made by Terry & Andrews Bristol ct
  7. Joseph Bautsch
    Dec 9, 2006
    1,113
    125
    Atlanta, GA
    #7 Joseph Bautsch, Nov 17, 2018
    I have what appears to be the same clock but has a Seth Thomas 30 hour works. They are identical to each other. I was lucky enough to get the original weights with the clock. These are probably what you need to run yours. The weights are 2 lbs. 11 oz. each, 4 1/2" long, 2 1/8" wide, 1 3/16" deep at the bottom and 1" at the top. There is a small taper bottom to top on one side. These will be very hard to find as originals. I would suggest you go to a metals supplier to find a mild steel block the size you need. They can cut any size you want. You will probably have to go with 2 1/4" wide and 1 1/4" deep. That is the standard size for these suppliers and should fit your clock. You can use an on line program and enter different sizes and it will give you the weight. Depending on the other dimensions used you can adjust the length of the block to get the correct weight. Hope this helps. (Sorry about the extra photos. Could not figure out how to delete the extra ones.)
    0-2.jpeg 0-1.jpeg View attachment 502799 View attachment 502800 View attachment 502801
  8. lxt123
    Apr 13, 2010
    22
    Thank you, the pictures are very helpful.
  9. Willie X
    12,774
    985
    It's amazing that you can have your question answered by JB in less than 12 hours!
    That's a very attractive clock. I can see where the narrower case made for much better proportions.
    Merritts #CW-116 might be just what you are looking for. Or you could still make cast lead weights about 3 1/4" tall to give you a little more run time and save About $40. Assuming you have a way to do the casting and some scrap lead.
  10. shutterbug
    43,785
    1,282
    I took care of it for you ;)
    Joseph Bautsch likes this.
