Standard Electric How do I wire a Standard Electric Secondary Clock without a master?
Discussion in 'Electric Horology' started by StandardElectricCollector, May 26, 2017.
  1. StandardElectricCollector
    StandardElectricCollector Registered User
    May 26, 2017
    21
    I have The Standard Electric Time Co. Secondary Clock, Type: FMT-SQ-12, GRC, Volts 120, Cycles: 60, Drive Motor: 5 Watts Max, Reset Motor: 5 Watts Max, Manufactured MAR 1961 Flextron. Right now I have it hooked up to an extension cord plugged into the wall the only thing is that I have to set it manually. I would like to run the reset motor without having to purchase a master clock. Do you have any recommendations on running the reset motor.
    I look forward to your response.
    Thank you in advance
  2. StandardElectricCollector
    May 26, 2017
    21
    https://attachment.outlook.office.net/owa/blakemiller@live.com/service.svc/s/GetAttachmentThumbnail?id=AQMkADAwATMwMAItOTIxZS1hMjBkLTAwAi0wMAoARgAAA2s%2FDwNM%2F5BEiSeQKbu%2BflYHAPNzm%2FnjsZxMhPKyJwLCYvsAAAIBCQAAAPNzm%2FnjsZxMhPKyJwLCYvsAAX%2BX%2F%2B8AAAABEgAQANk77sc7a%2B9DszQvsE%2B0wBA%3D&X-OWA-CANARY=wl6DHFep9EKLgnP1YxPzliAedmCQpNQYeabAer053vMDQvme8kK3OlANGk_m6vt89No_znKKUVQ.&token=eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiIsIng1dCI6ImVuaDlCSnJWUFU1aWpWMXFqWmpWLWZMMmJjbyJ9.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.wD1iSI06nCxddEm5Z5xkQJhZPMHRsWuaVjbbGJPQ-urUQhRKSZRybskNozUhlM0x-tbFY_FVCsLiWThNayqwPKt41TFt7MR61Zuxs4hWQwEKes1XvWLwnx0euRdnRXr56hN3GMPzvKHI6g2lesLhUxRbEYpGexVWwBZIhls5DyZ_9R1X7o0BFX1LS8UdjTcMGg53PDZ_UB8QJrTLxY8AkDAsJTbRyLxnZX4R0OImBlFZ3EnA-Npd-qPx_rIWlSTgijcn9LLsDdvejTz-uvRjIQ-u3yCg69sIvIkUHP3wbhlcr9o-tkAVhSn6HYWeVa-zbl07I4raGOGDMdrfoDElaw&owa:^utlook.live.com&isc=1
    https://attachment.outlook.office.net/owa/blakemiller@live.com/service.svc/s/GetAttachmentThumbnail?id=AQMkADAwATMwMAItOTIxZS1hMjBkLTAwAi0wMAoARgAAA2s%2FDwNM%2F5BEiSeQKbu%2BflYHAPNzm%2FnjsZxMhPKyJwLCYvsAAAIBCQAAAPNzm%2FnjsZxMhPKyJwLCYvsAAX%2BX%2F%2B8AAAABEgAQAA81aFhxOuBJm8mj%2FuU9YwU%3D&X-OWA-CANARY=wl6DHFep9EKLgnP1YxPzliAedmCQpNQYeabAer053vMDQvme8kK3OlANGk_m6vt89No_znKKUVQ.&token=eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiIsIng1dCI6ImVuaDlCSnJWUFU1aWpWMXFqWmpWLWZMMmJjbyJ9.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.wD1iSI06nCxddEm5Z5xkQJhZPMHRsWuaVjbbGJPQ-urUQhRKSZRybskNozUhlM0x-tbFY_FVCsLiWThNayqwPKt41TFt7MR61Zuxs4hWQwEKes1XvWLwnx0euRdnRXr56hN3GMPzvKHI6g2lesLhUxRbEYpGexVWwBZIhls5DyZ_9R1X7o0BFX1LS8UdjTcMGg53PDZ_UB8QJrTLxY8AkDAsJTbRyLxnZX4R0OImBlFZ3EnA-Npd-qPx_rIWlSTgijcn9LLsDdvejTz-uvRjIQ-u3yCg69sIvIkUHP3wbhlcr9o-tkAVhSn6HYWeVa-zbl07I4raGOGDMdrfoDElaw&owa:^utlook.live.com&isc=1
  3. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    156
    deceased
    You could wire it up to a switch to activate the reset motor.
  4. StandardElectricCollector
    May 26, 2017
    21
    Thanks for your response
    Can I run both off the same power source? Can I twist the two white wires together then? Is their a wiring diagram I can find? Would the switch go before the motor or after the motor?
    Thanks again
  5. Dick C
    Dick C Registered User
    Oct 14, 2009
    1,637
    55
    I cannot open your attachments. Instead I get the following message:
    440 Login Timeout
    Must I have Outlook on my system?
  6. StandardElectricCollector
    May 26, 2017
    21
    Hopefully this should work sorry for the inconvience.
  7. sundy58
    sundy58 Registered User
    Aug 23, 2014
    61
    Clock Manufacturer
    Donna, TX
    The black and white is the run voltage. Check the motor and labels on the clock for the voltage. The correction voltage can be different but that usually requires 2 white wires. Connect a momentary pushbutton switch across the black and red wires. The correction MIGHT be in the table I attached. If you can find the proper correction hold the momentary pushbutton switch closed as required to send a correction to the clock.
    Syncrhonous Protocal Information.pdf
  8. StandardElectricCollector
    May 26, 2017
    21
    Thanks for your quick response. Your pictures and chart. I am kind of confused on the second white wire. My drive motor has a black and a White wire, and my reset motor has a red and a white wire. They are both 120 Volts, 60 Cycles, and are both 5 watts max. 306072.jpg
  9. harold bain
    40,850
    156
    deceased
    Hook up both whites together, and to one wire of the power cord. Hook up the black to the other wire on the power cord, and run a switch between the black and the red.
  10. StandardElectricCollector
    May 26, 2017
    21
    Thanks for all of your help. I can't wait to try it!
  11. StandardElectricCollector
    May 26, 2017
    21
    Can I run both clocks on one cord?
  12. harold bain
    40,850
    156
    deceased
    How many clocks do you have? More than one can be wired in series.
  13. StandardElectricCollector
    May 26, 2017
    21
    Just two so far (I plan to get more). Thanks for your reply.
  14. harold bain
    40,850
    156
    deceased
    If you are unfamiliar with electricity, find someone who is familiar to check your work before plugging it in.
