How do I remove hand nuts if perhaps a glue was used?
MuensterMann
Mar 23, 2008
1,534
21
I have a nice old Hubert Herr cuckoo clock. I must remove the hands to remove the movement. However, the hand nut will not budge even with the use of pliers. I suspect a super glue or Loctite was used. I tried applying heat carefully, but perhaps I didn't get hot enough. The force of the pliers was not enough. I did try a little drop of WD40 overnight in case of rust, but that didn't do the trick. Help!!!
14,744
1,733
Heat ... and protect the dial, no matter how careful you think you are. :) Doesn't have to be that hot, around 350°F will do it. Willie X
MuensterMann
Mar 23, 2008
1,534
21
I was trying to a hair dryer up close and personal - and with a protection layer for the hands and dial. Perhaps a little more time.
Tim Orr
NAWCC Star Fellow
Sep 27, 2008
1,670
326
Boulder CO
Good afternoon, Muenster!
A small electronic-tip soldering iron can apply heat in a pretty localized area. If you have a variac or other rheostat (even a home-made controller using a light dimmer), you can cut the heat back. Unlike a hair dryer, you aren't spraying the heat everywhere.
Best regards!
Tim Orr
MuensterMann
Mar 23, 2008
1,534
21
Good suggestion Tim! I just tried using my soldering iron to strategically heat up the nut and threads. But, still no turn. Now I have the acetone out and will hope to get to penetration down into the threads and that the binding material doesn't like acetone!
SuffolkM
Jun 15, 2020
192
53
I recently dealt with a clock where the hour hand had been replaced and glued to the front of the canon (instead of being held using friction , i.e. a brass sleeve). I used a temperature controlled soldering iron and shielded the dial using a damp cloth. The smell and the fumes of superglue burning off are deeply unpleasant - try and keep the windows open and maybe a small fan on hand to move the smoke away from you!
MuensterMann
Mar 23, 2008
1,534
21
I applied a good amount of heat, but now the nuts turns with the minute hand shaft. The client said that he is not opposed to a new 8-day Herr movement, so I may just remove the movement (hacksaw the nuts off) and put in a new one. Looking at the new ones, they look just like all the Herr movements throughout the decades. Is it truly the same design as 70 years ago??
14,744
1,733
There will be at least a few differences.
Drastic measures to remove the nut:
#1 - Break off the minite hand and get someone to hold the clock so the nut is on a good size anvil, split the nut with a sharp chisel.
#2 - Break off both hands, then remove the movement from the case. Disassemble the movement. Now you can grip the handshaft with small
vise-grips, or in a vise, heat and remove the nut.
Heavy handed, Willie X
168,145
1,466,306
48,109
SimondsSays7
2,955
