• Upcoming updates
Mechanical WW How do I open this mainspring barrel?
Charlie Ryan
Dec 10, 2017
134
59
Annapolis, MD
This is a chinese 6497 I bought for learning the basics. I want to remove and reinstall the mainspring but I can't figure how to open the barrel. Any ideas?
Thank you
wrobbie
Dec 27, 2006
64
Singapore
I have the same Chinese movement, which cost ~$30 brand new. Be careful with the bridle at the end of the spring. Mine came off because it was poorly welded, and I had to buy a new spring ($12, ugh).
Besides that, the ratchet teeth on the winding and sliding pinions are poorly cut, and winding is nearly impossible without skipping. New parts would be another $30 or so. No thanks :)
Timekeeping is surprisingly good, and regulation is a breeze.
Al J
Jul 21, 2009
817
233
Canada
Put it cover-up like in the second picture on your bench anvil, and press down on the teeth with your thumbnails. The arbor will easily pop the cover out.
Certainly opening a barrel this way works, but please remember that it often distorts the lid of the barrel, so you need to check the barrel arbor end shake and adjust as required.
An alternative to the method described is to use canned air to open barrels - you just need to be able to fit the end of the tube over the barrel arbor, then give the trigger on the can a quick squeeze, and the barrel will pop open:
This works on barrels that don't have holes in them obviously, and the even pressure that the air applies to the lid tends to keep the shape of lid rather than create a cone shape that the method pf pressing the arbor on the bench will create. Doesn't work for all barrels, but whenever I can this is the method I use.
Cheers, Al
Chris Radek
Apr 13, 2014
1,262
727
Lincoln, NE, USA
timeguy.com
I knew someone would have a better way, and I'm glad that it isn't some special-purpose Bergeon tool for $2000. Thanks for sharing this, I might try it! Your canned air might work for front-loading cases too...?
Al J
Jul 21, 2009
817
233
Canada
It would likely pop the crystal out, but since these cans of air have a fair bit of pressure I would be a little concerned that the rush of air exiting the case after the crystal pops might cause some issues...maybe with the balance spring...
I don't open these cases that way, and typically I use specific tools that the brands used to sell for the watches that I have gathered over the years.
I've seen videos of people using a large syringe to generate pressure to pop a crystal, and I think that would be safer than canned air.
Cheers, Al
Charlie Ryan
Dec 10, 2017
134
59
Annapolis, MD
Cheers, Al
Also Very clever indeed! Thank you.
179,916
1,569,494
54,317
Eclectic Oddities
911
3,090
