I have come across a size 18 pocket watch, on the inside it has Marun Watch Company and it has Springfield below it. Maruin or Maruin is how it is engraved inside the watch on the movement. This is different than Marian which I can ind. It is a late 1800 type movement. It has a serial number on the movement of 927038.
When I first wound it it took right off and has continued to run as long as I keep it wound. The movement is closed and the balance wheel is mounted outside the movement with just the adjustment lever showing besides the balance wheel. The ceramic dial was broken in several places but it did have a flower design about 1/4 inch diameter in the center where the hour and minute hand come out, it does have a normal second hand spot on the bottom. It has no hands on it and whoever had it has made a photo copy of either the original dial or one like it then glued it over the broken ceramic one.
I would love to restore this watch but do not know where to start as I don't know who made it. I have tried under Marian Watch Company and Springfield both with no luck. Is there anyone out there that has seen one or may know what it is I have ? Thanks, Dennis
I do not have any better photos and I hope this makes sense.
