HappyPixie
I recently bought a wall clock in France (north of Mont St Michel) and it seems to match what people call a Comtoise Morbier movement. The clock was in pieces, the panel with the movement was separated from the coffin-shaped wall box which itself had broken in two. The dial is a sheet of glass with a paper sheet behind on which the hours are inked and a steel disk behind that which is held in place by the brass rings at the centre and where the winding spindles are. I turned both springs a few clicks and added a homemade pendulum (a bent piece of wire with a few small lead weights) and when I set it swinging the clock ticks for a few minutes and then slowly stops – this is when it is upright enough that the pendulum doesn't foul with anything and swings freely.
I know nothing about the terminology of clocks nor their workings, but since the pendulum was missing, I assume it needs to be a certain length or weight or both. Any advice would be appreciated.
My wife's initial suggestion was to put a modern battery-operated mechanism in the face and keep the beautiful mechanical structure on a shelf to be appreciated. I'd love to get it working but clocks ain't my thang. Woodturning, yes. But not clocks.
If anyone cares to speculate on a date, that would be amusing. I noticed in various NAWCC threads that people consider the placing of the pendulum to be important for dating. It's at the back, has the pivot near the top and is linked to another arm at the back left that moves something else (probably). I've included pictures below. Thanks in advance.
Steve
Steve
