I use a Rivett watchmaker's lathe almost daily, and I have a few collet-shaped chucks with an internal 8-48 thread. Besides the internal thread, there is also a very small area near the tip of the chuck's internal perimeter that is tapered. I'm assuming the function of the tapered area is to register with a matching tapered area of some wax (or shellac) chucks. My question is how can I accurately measure the angle of the taper? I'm attaching close-up pictures that I hope will help.
My question arises because I made a set of brass pieces (also pictured here) to fit in the thread and hopefully match the chucks. The 8-48 thread fits well, but determining a matching taper angle is proving to be a challenge. I cut the taper of the brass pieces at 30 degrees with my Rivett sliderest. I made marks on the brass tapered areas with a Sharpie pen, and when I screwed down each of the three brass pieces into one of the chucks, I saw a circular ring (also pictured here) in the marks that seemed to indicate an edge rubbing the mark, instead of an overall smudge. It seems clear to me the chuck's registering ring is NOT 30 degrees. But what IS the angle? How to measure it? There's only one way my little pea-brain can think of, but it's convoluted and fits my habit of making mountains out of molehills - so I thought I'd try here first.
I'm thinking that even if my angle is off a few degrees, the circular parts that mangage to touch each other should be enough to assure concentricity. But I guess I'd rather pursue perfection rather than "good enough".
On to the pictures... here are the chucks in question:
The tapered area:
The three brass pieces I've already made with the 30-degree shoulder:
Close-up, with red arrows pointing to where the chuck rubbed my Sharpie marks:
So... how can I measure the angle of the tapered area in my second photo? Again, I have an idea that I think would work, but I'm not a machinist or a mechanical engineer - so maybe there's a simple way that I don't know about.
The tapered area:
