Horological Best Practices
Kieran McCarthy
Dec 15, 2020
23
Does a relatively concise list of Horological Best Practices exist? The Dos and Do Nots of clock repair.
For example, in my relatively short Horological journey, I have adopted some basic principles.
1/. Be meticulous when cleaning, especially pivots, pivot holes/oil sinks, and pinions.
2/. Use the correct oil in the appropriate quantity to the precise location.
3/. Only use new taper pins, correctly cut and neatly filed to length.
4/. Only use brass to steel, and steel to brass taper pins.
5/. After plate assembly, check for binding and excessive play in all wheels, etc.
This is just a flavour of what I mean. But such a well-defined checklist if one exists would be great for us newbies.
Regards Kieran
Reactions: DeanT
46,195
1,785
In the repair forum, at the top there are some stickies that you might benefit from. One of them "Errors newbies make and how to avoid them" is one that is both entertaining and useful. "Best practices" is an ever evolving thing that is quite a bit different now than it was 100 years ago. And it seems every repairman has a different opinion of what it consists of.
13,573
1,356
What Bug's just recommended.
That written matter at the top of this page is the best knowledge base I know of. It's sort of a compilation of what all the books might teach you.
I would not discourage what you are doing there, especially if it helps you learn. However, I can guarantee that your list will become to long and to complex at some point and most of your points will be arguable, even amongst career pros.
Good luck, Willie X
Bruce Alexander
NAWCC Brass Member
Feb 22, 2010
7,334
778
Kieran,
In addition to the excellent advice you've received
Very generally...
Take your time and do your best.
When something goes wrong and you're at a loss, work your way from the power source up or from the escapement/governor down through the trains. Check every wheel, arbor, metal joint, spring, tooth, pinion, pivot, pivot hole, lever, cam, detent, pin and anything else the invisible power "touches". Test with finger power before you apply weight or spring torque.
Use your ears and sense of feel in addition to your eyes.
Also, do NOT change factory settings without a very good, clear reason.
When in doubt, know when to stop and ask questions
Work safely. Enjoy the challenges you'll face and the opportunity for growth that they'll bring.
Have fun,
Bruce
Reactions: DeanT
JimmyOz
Feb 21, 2008
786
165
65
Gold Coast Qld
I agree with the "filed to length" (the sharp end where cut), however if I am doing an old clock movement I use the same taper pins (if they are not nails) and clean them up and put them back in the movement.
So there you go a difference already, a bit like Lawyers, they all study the law, however have different opinions on every part of it.
roughbarked
Dec 2, 2016
5,946
796
But they have to employ somebody to wheel the reference books around with them.
JimmyOz
Feb 21, 2008
786
165
65
Gold Coast Qld
Of course they do ... if not there wigs could blow off as they would have no hands left.
Op's sorry to the OP getting off subject :offtopic:
Reactions: roughbarked
Michael Linz
Oct 2, 2014
95
Georgia
For me, I prefer to keep everything as original as possible, so unless the taper pins are junk, I clean and reuse them too.
13,573
1,356
Sometimes, it's hard to decide what path to take. Like when it has one missing pin and the ones left are all different ... I usually leave things as they were except for adding a pin where one was missing.
NO, I don't leave things like: sewing pins and paper clips. :) Willie X
164,923
1,435,151
85,879
deeqdacad
2,872
