Greetings all,
As most are aware, a while back I was given a running Accutron by a generous registered member. I'm now at the point of disassembling the movement but I'm in a bit of a quandary before I dive in in earnest.
The 218 series service manual I have shows Bulova using what was then the latest model of test kit, a model 600. And apparently the 600's came with different leads. One of the sets was for the 214 Accutron, the other for the 218's. But because the 700 kit has a different lead design, I'm unsure as to how to hook it up to the movement/movement holder. My manual shows a different lead that should be attached under the battery clamp at the pivot/insulator side. But the 700 doesn't have a flat lead that would go under the strap. Instead it has two small toothless alligator clips colored yellow and blue. In the same three wire group is the male plug for the movement holder.
My question is, how do I hook up the clip leads from the 700 to get my readings from the watch to check and adjust? Many thanks. Cheers.
