I want to build a hooded wall clock but use some parts from a worn out grandfather clock. I have an emperor grandfather that uses the 451-050 92cm movement. That movement doesn't chime nor strike worth crap. I want to get a 241-030 55cm movement. What I wanted to know is if I could use the chains and the time and strike weights off the bad movement for the new movement? Everything on the grandfather clock I could use except the pendulum and chime rod assembly and chime weight. Will my thinking work?
