Homemade Screwdrivers
Discussion in 'Horological Tools' started by watchtinker, Dec 29, 2017.
  1. watchtinker
    watchtinker Registered User
    Dec 25, 2016
    78
    So I have been wanting some more screwdrivers, but I haven't been able to bring myself to spend the money on the. in the end I decided to try to make my own. After about four tries I managed to get all the kinks worked out. I don't think that once I factor in the time I spent making them I saved at all, but it was a fun project. I haven't made a blade yet, since I was going to use music wire, and I haven't got any. I'm not sure why the watch appeared, but I guess it doesn't hurt anything. DSC_0059.JPG 300943.jpg
  2. David S
    David S Registered User
    Dec 18, 2011
    7,146
    222
    Brockville, On Canada
    If what I am seeing with the drill bit is the start of the finished product, it looks pretty good. In the absence of pivot wire, can you not just use worn out drill bit shanks? Or even sacrifice good ones, they are pretty cheap at out local box store on sale.
    I like it when folks make rather than buy.
    David
  3. watchtinker
    Dec 25, 2016
    78
    Well I haven't got any worn out drill bits, but music wire is only about 10 dollars for 25ft
  4. karlmansson
    karlmansson Registered User
    Apr 20, 2013
    2,519
    94
    Doctor
    Linköping, Sweden
    You'll need a lot of different sizes of Music wire though in order to get a set of screwdrivers.
    Nicely made handle!
  5. Dushan Grujich
    Dushan Grujich Registered User
    Jun 20, 2003
    561
    23
    Watchmaker
    Bondi
    G'Day Karl!
    Not necessarily. If the lathe is available, and a TC cutter, one can then use a single size wire. Mounting end can be left as is and the working part turned down to the required diameter. Often done so with a collet style screwdriver blades, Belzer used to do it, even seen on some of the Vigor brand screwdrivers.
    Cheers
    Dushan
  6. wrobbie
    wrobbie Registered User
    Dec 27, 2006
    56
    BHI DLC student
    Singapore
    Chinese screwdrivers are about $10 on ebay, including crappy but functional stand. The blades can be all crooked and the finish of the tips is generally atrocious, but that can easily be remedied. I use one set of Chinese drivers ground to rather fat tips, for quartz watches.
    I understand the joy of making your own tools, but usually prefer the route of modifying/improving a cheap off-the-shelf set, if possible.
    RL likes this.
