Homemade Pivot Gauge Layout
Discussion in 'Horological Tools' started by ddhix, Jul 6, 2017.
  1. ddhix
    ddhix Registered User
    Apr 7, 2011
    110
    17
    US Air Force
    Texas
    #1 ddhix, Jul 6, 2017
    Hi All,
    I created a few documents for you all. After seeing how much pivot gauges cost, I decided I might want to make my own.
    All you would really have to do is print off the excel spreadsheet onto a standard piece of paper, and then have someone with a laser etcher print the document onto a piece of brass, or other metal of your choosing. then insert the bushings you want into the piece of metal to create your own pivot gauge.
    The "Pivot Fit Test" section should be wide enough to fit any bushing.
    The "KWM Extra Pivots" spreadsheet is better than the current KWM Pivot gauge on the market.
    And the "Bergeon with American Sizes" spreadsheet supplements the current bushing selection offered by bergeon, by incorporating the American made bushings offered on Timesavers.
    The only thing, though, is that American Made Bergeon 113, 115, 117, 119, and 120 are all 4.00mm diameter bushings, and would require a 3.97mm reamer to cut the proper sized hole, so those roman numeral indicators are replaced with a "?"
    Also attached are two spreadsheets with KWM and Bergeon bushing tables. The KWM table is the same one found in timesavers, I simply copied that format and incorporated Bergeon bushings into it. In the table, any number with a "B" before it is a bushing that Bergeon makes. Any any three digit number is going to be an American made bergeon sized bushing.
    I hope you all enjoy.
  2. bartmes
    bartmes Registered User
    May 20, 2012
    19
    Thanks for your work and post.
  3. Bob Murray
    Bob Murray Registered User
    Aug 15, 2011
    10
    Thanks very much!
  4. Red_Grouse
    Red_Grouse New Member
    Mar 31, 2019
    Thanks very much :).
  5. sloker
    sloker Registered User
    Jul 10, 2019
    25
    Engineering Manager
    Plano, Texas
    Thanks very much!
  6. Bob Murray
    Aug 15, 2011
    10
    Thanks very much!
