Hollow Column Clock ~ Weights
Discussion in 'Wood Movement Clocks' started by C Anthony, Jun 27, 2017.
  1. C Anthony
    C Anthony Registered User
    Apr 13, 2014
    34
    Manager, Retail Flower Shop and Greenhouses
    Charles City, IA
    We are working on my E. & G. W. Bartholomew WW Hollow Column Clock. The clock did not come with any weights and we are attempting to at least get the clock running properly by experimenting with various weights. We know that these clocks took special size of weights, but are not certain as to the actual weight each one should be. In one publication, someone made reference that the Bartholomew's used a heavier weight for the hollow column clock. Does anyone have one of these clocks that might share pictures of the correct weights, so we can improve our search for correct weights, but also the correct weight of the weights in order to have the clock running correctly.
    Thanks in advance
    Christopher
  2. George Nelson
    George Nelson Registered User
    Oct 5, 2007
    886
    Tennessee
    Hi, Christopher,
    Years ago in the 1970s, a man by the name of Versage hand cast reproduction lead weights for almost all the known weight clocks. While he has passed away and his weights are no longer in production, I do have a copy of his catalog reference to the weights you need:
    [​IMG]
    Apparently, both the time and strike side weights were the same.
    Hope this helps!
    All the best,
    George Nelson
  3. C Anthony
    Apr 13, 2014
    34
    Charles City, IA
    This certainly helps. We have it running that is made a complete 23 hours, though it gained 20 minutes during that time. Some more adjustments needed, but we are getting there.
    Thanks for your assistance.
  4. George Nelson
    Oct 5, 2007
    886
    Tennessee
    Absolutely no problem at all. With a time gain of 20 minutes in 23 hours, you should be able to adjust that out with the pendulum adjustment.
    Any chance of a picture or two of the clock? Hollow columns are not plentiful and I know everyone would love to see it!
    Best,
    George
  5. C Anthony
    Apr 13, 2014
    34
    Charles City, IA
    First thing I noticed about the clock was the suspension spring. It was very short, the bob barely hung in the opening of the lower door. So that right there will correct much of the gain in time. I will get some pictures of the clock as soon as I can. It is at a friends house, as he has more tools that I have when it comes to extensive work on clocks.
Similar Threads - Hollow Column Clock Forum Date
Riley Whiting 3/4 Column and Splat Wood Movement Clocks Mar 30, 2017
George Barber column and splat Wood Movement Clocks Jun 6, 2016
Eli Terry and sonpillar and column needs verge Wood Movement Clocks Apr 12, 2014
Rare Luman Watson hollow column movement, mahogany plates... Wood Movement Clocks Jan 20, 2012
