Holding a quartz motor
fuzz1
Mar 30, 2022
119
Hi
I'm trying to figure out how to hold this simple quartz motor to the dial I bought for a clock diy construction.
It doesn't have any screw
Any suggestions most welcome.
Thank you
fuzz1
Mar 30, 2022
119
Hi
Thank you. Was wondering if i missed something.
I came with almost same conclusion that I need glue to fix it.
Vernon
Dec 9, 2006
1,392
259
57
Many are held in place by just the washer and nut that go on the hand shaft. Washers are thin and of metal and/or rubber which keeps things from loosing. If you must glue, maybe use rubber cement?
Vernon
fuzz1
Mar 30, 2022
119
Hi
I used double sided tape. There is no washer on that particular movement and was just surprised when i received it.
I made a diy clock from an ice cream cup and my kids did no want to believe it was a real clock. Unfortunately they did not want the work of art in the living room :)
Vernon
Dec 9, 2006
1,392
259
57
Thanks Wimber, I should have looked closer. I haven't seen one like that.
Vernon
Top
