Hickory Dickory Dock Help
wow
Jun 24, 2008
7,747
1,767
78
Pineville, La. (central La.)
Got this one in for repair with no pendulum. Never worked on one before. Does it have a short pendulum or one that extends down? Any photos would be appreciated. Thanks.
Will
C7521320-FBCE-46F8-99D9-7894F2655C07.jpeg CDA5968B-D382-4435-95F2-4406FCA098A8.jpeg C94BE32B-2EAB-42CD-96DE-19CFD9838E70.jpeg
KurtinSA
Nov 24, 2014
6,127
711
San Antonio, TX
Some info here:
Searching for "Hickory Dickory" found lots of past posts.
Kurt
lpbp
NAWCC Star Fellow
NAWCC Life Member
Aug 25, 2000
3,059
96
This is the remake by Horolover with a German movement. It's actually called Dickory Dickory Dock, probably to not enhance on Copyright.
R. Croswell
13,203
3,000
www.greenfieldclockshop.com
Thanks, I thought so. It looks too new to be an original. Who made the originals?
The originals were made by Dungan & Klump, however the movements for the model 1, & 2 were manufactured by New Haven. The model 3 was only a prototype. The model 4 & 5 had movements made by Sessions. It is quite an interesting story and can be found in A Supplement to the BULLETIN of the Nationmal Association of Watch and Clock Collectors, Inc.. 4 1966 Summer 1966. The article is by Charles Terwillinger and is titled, Elmer Ellsworth Dungan and the Dickory Dickory Dock Clock. I expect it is available in the NAWCC library.
Dungan was not a clock maker but made the first Dickory Dickory Dock Clock for his little daughter. His house at Fort Washington, PA became the home of Zake's Cakes, now Zake's Cafe. Dungan had also built a large clock in the cable end of his house. The house can be seen here and it still has a clock, but probably not the same one Elmer built.
50,148
3,295
Mine doesn't have a pendulum (balance wheel), but the basic operation is that the string operating the mouse turns one turn per hour, raising the mouse one number. At 1:00 there's a method to allow the mouse to fall. In mine, the driving wheel has a notch where the teeth are disengaged and the mouse falls to the lower 1:00 setting. When it falls, a bell rings and it starts over again.
R. Croswell
13,203
3,000
There have been a number of "mouse clocks" produced. The original Dungan & Klump, models 1 & 2 had a balance wheel movement that lived in the bottom of the case and used a chain to lift the mouse. They struck the hour each hour on a small bell. At "1", when the clock struck, a gizmo at the top of the clock released the mouse to drop. The models 1 & 2 never worked very well. The model 3 prototype supposedly fixed the problems but was never produced. Dungan had a falling out with New Haven and the model 4 had a Sessions movement with a pendulum at the top. The model 5 is almost never seen and was a table or shelf clock, smaller in size with a conventional round clock dial above a slot where the mouse just went up and down didn't do anything else.
I believe there are some Asian knock offs of the model 2 and 4.
The Horolover models that I have seen were smaller than the original Dungan & Klump models and had a small balance wheel movement in the top with a spool and string to raise the mouse and a driving wheel has a notch where the teeth are disengaged and the mouse falls, like you described. This is probably the one you have.
If WOW's clock has a German movement, perhaps it is a Horolover reproduction that I'm not familiar with. Whoever made it, I'm sure it was designed to look like the original Dungan & Klump model 4
wow
Jun 24, 2008
7,747
1,767
78
No name on it. Looks like the Horolover repro to me. String broke so I replaced it with monofilament fishing line. Mouse is now happily climbing as it runs. I set it at 1:00 today. We’ll see where the little varment is tomorrow morning.
R. Croswell
13,203
3,000
The diameter of the string is critical. Too large and the mouse gets to "1" early, too small and the mouse gets to "1" late. It won't keep time unless you have the correct string. I believe Horolover has the correct replacement string, if it is a Horolover.
Here are some pictures of the Horolover "mouse clock". It is only 24" tall and should have the Horolover name on the movement. By comparison, the black and white image is an original Dungan & Klump, model 4 as shown in the Bulletin (see post # 6). Yours does not look like the Horolover models that I have seen, and while it is similar to the D & K model 4, it isn't exactly a match. If yours has no markings, I would suspect that it may be one of the Asian copies of the D & K model 4. If it should turn out to be a genuine D & K model 4 (they were known to make changes during their production runs) it could be worth some serious money.
DSC08064.JPG horolover mouse 1.jpg horolover mouse 2.jpg horolover mouse 3.jpg D&K model 4.jpg
Here is a side by side image of the movements.
Top Bottom
