Hey buddy, could you spare a...
Discussion in '400-Day & Atmos' started by Mike74, Oct 12, 2011.
  1. Mike74
    Mike74 Registered User
    NAWCC Member Sponsor
    Jan 26, 2010
    Anerican Airlines
    Oneonta, Alabama
    Hi, just asking if someone has a spare small spring to pulley, on my Atmos.At a reasonable rate,or free to me would do.
    With kind regards, Mike
  2. Mike74
    Jan 26, 2010
    Anerican Airlines
    Oneonta, Alabama
    Thanks for checking post. I have a spring. Facebook is so great.:D
  3. Kevin W.
    Kevin W. Registered User
    21,677
    217
    Glad you got the part needed Mike.:):)
  4. Spaceman Spiff
    Spaceman Spiff Registered User
    Jun 19, 2006
    1,381
    Semi-retired - with a degree in Creative Writing
    St. Petersburg, Florida
    Facebook?? For clock parts??
    I'm curious, how did you achieve that? Do you belong to some sort of Facebook clock group?
    Just wondering.
  5. Kevin W.
    21,677
    217
    I have a few Facebook friends who do clock repairs.:):)
  6. Mike74
    Jan 26, 2010
    Anerican Airlines
    Oneonta, Alabama
    Yeah, found a few good trucks there too.:rolleyes:
    -> posts merged by system <-
    Thanks Kevin,good info.:confused:
  7. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    143
    deceased
  8. Spaceman Spiff
    Jun 19, 2006
    1,381
    Clocks? Trucks?
    Wow, I'm totally befuddled.
    I'm on Facebook every day and have never seen anything like what you seem to be describing.
    And you're sure you're talking about Facebook, and not CraigsList?
    Wow.
  9. shutterbug
    40,775
    722
    I had to close my facebook acct. Took too much time! I guess I'm not all that sociable, or would rather not 'listen' to prattle :D
  10. shutterbug
    40,775
    722
    I'm trying to understand what you mean, hope .... but can't decipher what part you're talking about. Can you describe it a bit more for us?
  11. hopedragon
    hopedragon Registered User
    Nov 30, 2011
    41
    sure...when you take the clock apart look at the back of the face. There is a gear with a long piece that goes straight through another gear with a sleeve.....the long piece is the one that the pin goes in to hold the hands......The "sleeve" has pieces on it that the minute hand rides on.....the sleeve on my clock is broken.....I will try and take pics of it again this afternoon....
  12. shutterbug
    40,775
    722
    So the sleeve is a gear? Sounds like it might be a pinion gear. If not a gear, you might be talking about the hour cannon ... but I doubt that would be broken. So is the gear broken in half or just cracked? If cracked, it could be repaired.
  13. MartinM
    MartinM Registered User
    Jun 24, 2011
    2,998
    86
    El Dorado, CA
    #13 MartinM, Jan 3, 2012
    Sounds like the hour wheel to me. ("y","c" in the linked drawing)
    http://en.wikipedia.org/wiki/Wheel_train_(horology)#Motion_work
    A common problem on these is damage from trying to remove the hour hand and not knowing how delicate the assembly it is pressed onto is.
    If you don't know how to remove the hour hand, it's easy to break teeth on/bend/break/separate the gear from the "sleeve" (pipe) as the metal is thin and restrained only on one point of its circumference (usually a clip or screw whose primary purpose is to secure the minute wheel) when installed.
  14. hopedragon
    Nov 30, 2011
    41
    If you look at the diagram there are prongs that the minute hand fit on.....the prongs are broken off so theres nothing moving the hands......make sense? Thank you so much for the diagram:)
  15. MartinM
    Jun 24, 2011
    2,998
    86
    El Dorado, CA
    Ah. So the distal end of the cannon pinion is either worn-down or broken off. I've never seen one where the pin that secures the hand goes through it. Actually, I can't inagine a system where that could be a working design. The pin goes through the center staff.
    Rebuilding the end of the cannon pinion could be difficult without a good model to work from. The length of the pipe is fairly critical to proper operation. Especially on the designs that use a taper pin to hold on the hands.
  16. hopedragon
    Nov 30, 2011
    41
    #16 hopedragon, Jan 3, 2012
    100_0507.jpg 100_0503smaller.jpg yes the pin goes through the center shaft...its the place where the minute hand attaches...These are the 2 pieces i need
  17. shutterbug
    40,775
    722
    Looks like you started a separate thread on your Kundo. Read my post there :)
  18. Mike74
    Jan 26, 2010
    Anerican Airlines
    Oneonta, Alabama
    I need the brass centering clamp for regulator on Atmos 528 cal. Thanks
