Herschede Five Tubular Bell Grandfather Clock Chiming Question
Discussion in 'General Clock Discussions' started by Brian Renaud, Oct 12, 2019.
  1. Brian Renaud
    Brian Renaud Registered User
    Mar 1, 2009
    14
    I have a mid 1950s Herschede five tubular bell, Westminster chime only, grandfather clock (not the 250). The timing runs great, but the chiming train runs through several (3 1/4 or even 4 1/4) Westminster chime cycles before striking on the hour. The clock has a slot for a night silencer, but whoever serviced the clock before I bought it used removed the silencer arm/lever. The chiming train didn't go through all of these cycles when I bought it a couple of years ago. It was one straight Westminster cycle then. I've earlier canvassed NAWCC members about installing/retrofitting a night silencer arm and received some responses, but this is a different issue. The (much heavier) chime weight drops probably twice as quickly over a week as do the other two weights. Any comments or recommendations on what the problem may be and potential fixes? Thanks for any input.
  2. Isaac
    Isaac Registered User
    Aug 5, 2013
    807
    125
    Student
    Sounds like some oil has dried up and become sticky, or there is some wear in the movement. Either way, it's probably due for an overhaul. Some pictures would also be nice!
    Isaac
  3. Bruce Alexander
    Sponsor NAWCC Brass Member
    Feb 22, 2010
    6,872
    620
    Hi Brian,
    I think Isaac may be on to something there. It sounds like the Quarter Rack is not being gathered reliably. If so, that could be due to wear or failing lubrication.
    You'd have to catch it in the act to be certain. In order to do so, you could remove the hands and face/dial, then replace the minute hand to manually advance through several hours one quarter at a time to observe the movement's action. As you manually advance the minute hand, I would suggest that you apply force near the base of the hand and not at its tip. I think you're less likely to bend or damage the minute hand that way.
    In any case, it sounds like you're overdue for some maintenance, possibly with some repair.
    Good luck,
    Bruce
  4. shutterbug
    43,407
    1,222
    Yes, pictures of the front of the movement please. Even better, a video. Put it on Youtube and link to it here.
  5. claussclocks
    claussclocks Registered User
    Mar 14, 2013
    830
    236
    Texas
    I am currently servicing a 9 tube with the same problem. The Chime weight runs about 3 inches faster down than the others. After setting it up on the rack to run I discovered that the Chime gathering pallet pivot hole is worn up and down so that when it comes around it bounces up in the worn pivot hole and does not engage the teeth on the rack deeply enough. This allows the rack to re-drop allowing the chime cycle to repeat as many as three times before it catches enough to finish the cycle. It doesn't look wrong because at some point the auto correct resets at an hour strike.
    The solution is to bush the pivot hole front and back.
    Check and see if this might be your problem as well
    DPC
  6. 124Spider
    124Spider Registered User
    I have a 9-tube Herschede that did the same thing a few years ago. I took the dial off, and, sure enough, someone had put springs to keep things shutting down at the right point, and one of those springs had stretched enough that it wasn't closing. A bit of oil on the pivot, and a bit stronger spring, and all was well.
