Herschede 9 Tube broken part
Discussion in 'Clock Repair' started by TEACLOCKS, Nov 9, 2018.
  1. TEACLOCKS
    TEACLOCKS Registered User
    Mar 22, 2005
    2,350
    77
    Clock service & repair
    Santa Rosa Calif.
    I was working in the lab late one night, and to my surprise I broke this Herschede gathering pallet (Strike)
    Her2106 or Her22106.
    (The one on the right in the picture)
    Just wondering if somebody might have a hand full of these they might want to part with one.
    Please Lloyd
    Part # from R&M Imports.
  2. wow
    wow Registered User
    Jun 24, 2008
    4,269
    327
    Retired Music Minister
    Pineville, La. (central La.)
    Tea, if you don’t find one, you can repair that one by drilling one or two small holes in each side of the break and inserting steel pins for strength, then solder or loctite them and clean it up so the solder or loctite does not show. You could just make a new one, but the square hole might be a problem.
  3. shutterbug
    43,746
    1,280
    Timesavers has both left and right GP's that you can modify to fit your movement.
  4. Bruce Alexander
    Sponsor NAWCC Brass Member
    Feb 22, 2010
    6,997
    658
    These parts are subjected to a lot of force as they lock the train. It was probably already cracked and you just were just lucky enough to be there when it failed completely. It will take a pretty strong repair joint if you decide to try that route.
  5. TEACLOCKS
    Mar 22, 2005
    2,350
    77
    Santa Rosa Calif.
    Not going to repair.
    Thought I could start out with one that is real close first.
    I have bought one awhile ago from R&M and fit it to another Herschede movement, but you know that story.
    The one on the left is real close, I'm going to see if it can work with a small amount of work.
  6. Jeff Salmon
    Jeff Salmon Registered User
    670
    This could be easily laser welded.
  7. R&A
    R&A Registered User
    Oct 21, 2008
    4,203
    107
    U can make one that works with a pin. Put a set screw and you can lock it in 4 positions same as squared. Hey we will have to do with what we have if this company never reopens.
  8. Willie X
    Willie X Registered User
    12,774
    985
    Any jeweler can braze that piece back together. You would need to cut a deep narrow 'V' about half way through the piece on one side of the break. Willie X
  9. R&A
    R&A Registered User
    Oct 21, 2008
    4,203
    107
    Just remember what ever you do You will still need the length for it to lock out. Shorter is not much of an option
  10. Jeff Salmon
    670
    I had a clock repair with a Westminster chime with 4 coiled gongs and one was broken. the laser welder worked fine. This pallet could easily be brazed by a jeweler.
