• Upcoming updates
Herr Standard
S
stilckdv
Hi, I've gotten this Herr Standard that needs the suspension unit replaced. The TimeSavers Catalouge lists four for the Standard! #20A 54, #20B 54, #27A 53, and#27B 55. Do those relate to the Lenght? There are No markings on the back of the Movenent except to say it's German, (0) Jewels, Unadjusted. How do I determine Which Unit to Order?
John Hubby
Senior Administrator Emeritus
NAWCC Star Fellow
NAWCC Life Member
Sep 7, 2000
12,296
281
The Woodlands, TX
stilckdv, do you have a copy of the Horolovar 400-Day Clock Repair Guide? It will include a back plate of your movement and the suspension unit needed will be shown. If you don't have the Repair Guide, please post a photo of the back of your movement with the suspension guard removed, and someone here will be able to identify it and provide the correct suspension unit.
John Hubby
John Hubby
NAWCC Star Fellow
NAWCC Life Member
Sep 7, 2000
12,296
281
The Woodlands, TX
stilckdv, best I can tell your clock has Plate No. 1159 from the Repair Guide. This clock requires suspension unit no. 27A, 0.0040". I note on the Clock Repair Forum that you contacted Horolovar and they also gave the same info for the unit. That should do the trick.
John Hubby
180,087
1,571,001
54,369
wbaNev
911
3,102
