HERMLI MOVEMENT 1161-053h 94cm
Discussion in 'Clock Repair' started by sparkey0151, Sep 12, 2017.
  1. sparkey0151
    sparkey0151 Registered User
    NAWCC Member Donor
    Aug 9, 2016
    225
    horologist
    liverpool uk
    Hi just wondering can anybody give me a simple answer to the length of a pendulum, the HERMLI movement is a 1161-053h and it states 94cm is this the length of the pendulum tip to tip of screw thread ? with a 6" bob.
    regards john
  2. Willie X
    Willie X Registered User
    8,148
    32
    #2 Willie X, Sep 12, 2017
    If you are buying a replacement pendulum a Hermle 94cm pendulum should work. If you are making a pendulum, make a trial pendulum first by taping the desired pendulum bob on the desired stick. When you get the clock to keep time, cut the stick off. Be sure to cut the stick a couple of inches long because cutting off the extra stick will make your clock run faster. Then you will have to lower the bob a bit. The final cut should put the regulation nut near the center of the threaded rod.
    It's the same deal for any type pendulum. A wild guess on your pendulum length, from hook to tip, would be in the neighborhood of 32". This would be for a 6 1/2" plain bob with a 3/4" oval stick. Your mileage will vary.
    I wish there were a precice number to give you but pendulum length is based on a number of variables and can only be found by experiment. The ole trial and error thing. It might take you a week or two, without a beat counter, to get a good rate. Much less with a beat counter. However, with or without a beat counter, the actual work time will be about the same. And, fine adjustment will usually take several week-to-week runs.
    Good luck,
  3. sparkey0151
    NAWCC Member Donor
    Aug 9, 2016
    225
    horologist
    liverpool uk
    Thank you will, that sounds just what I wanted simple and straight to the point,
    Regards John😀
Similar Threads - HERMLI MOVEMENT 053h Forum Date
Quartz Movement Help Clock Repair Yesterday at 1:04 PM
Regula 72 Movement Chain Gear Clock Repair Nov 12, 2017
Hermle weight driven movement on cables with 9 tubular bells - query weights?? Clock Repair Nov 7, 2017
Hubert Herr Model 60 Cuckoo Movement Set Up Clock Repair Nov 6, 2017
Need Help Getting Hermle 451-053H Chiming Again Clock Repair Oct 27, 2016
