Hermle Westminster Chime clock.
Rod McLeod
Mar 3, 2019
79
I want to buy a lever for this clock. It is the lever which attaches to the shut-off lever on the clock and projects thru the case beside the dial so I can turn the chime off. Rod.
14,083
1,508
Rod,
These come in several shapes and sizes. Some photos would be necessary to help you pick the right one. Willie X
14,083
1,508
Rod,
No photos yet and it looks like everyone's crystal ball in in the shop ... Willie X
Rod McLeod
Mar 3, 2019
79
That is older than I had imagined it to be. Can you provide a picture?
Hi Mark. I tried posting a picture with no success. The lever I need is the one that attaches to the lever on the front of the movement that turns on/off the chime sequence. It mounts on the lever with a small set screw and then comes thru to the front of the clock thru a slot beside the dial. Does this help? Thanks, Rod.
14,083
1,508
That's called the 'chime selector' and comes in about 6 different lengths.
It's measured from the flat lever to the tip of the selector.
Note, to long would be better than to short. :)
Rod McLeod
Mar 3, 2019
79
Thanks Willie. Now if I can find someone who can supply same, I would be grateful. Rod.
Rod McLeod
Mar 3, 2019
79
Hi Willie, do you sell these chime selectors? Rod.
14,083
1,508
Google 'Hermle parts' or look at the 'clock supplies' at the top of this page.
With no photos, numbers, or measurements, you will have to "get lucky" on this one.
166,231
1,448,293
86,745
Timemaestro
2,906
