I cleaned a Hermle 451-053. Other than being covered in Liquid Wrench and crud it was in decent condition. After reassembling and lubricating, the movement was placed on the test stand and like many Hermle's, it held a flat rate of 3960 BPH measured at the pendulum. No variation for the quarter warn...just a consistent 3960 beats every hour. Great, right? Well, when I installed the hands, I find it's losing 30 minutes a day. After doing the math for the 30 minute loss, I find the rate must be about 4042. So, I cranked the pendulum up. It's now running 4037...maxed the pendulum out! ..and it's still losing time
I know the obvious area is the compression spring on the center wheel. The hand has noticeable tension when readjusting, so I don't think it's the center wheel spring. I just checked the star cam assembly..it's tight. Before I tear this down again to count teeth, is there something obvious I'm overlooking? The clock runs great and holds a consistent rate at the pendulum. Can't increase the rate any further, but still losing time at the hands.
Thanks,
Bill
Thanks,
Bill
